That's why I am trying to make the tap a hub is pretty much impossible to find smile I tried an old one I had that claimed to be a hub and it turned out to be a switch.
Edit: you could try forcing all three ends of the connection to use half-duplex, and turn off auto-negotiation -- then the tap might actually work.
I won't be able to change anything like that.
So aside from finding a hub there is no way to capture incoming and outgoing with only one nic ?
Edited by msaeger (17/04/2010 14:09)
