Is it possible to do a variant of the thing you just showed, adding multiple fields, altering both the X/Y position and the the "00:00" in each one, thus causing the time to move about the screen, yet stay on the screen the whole time?
I don't know, why don't you try it?
If you bounced it around the screen's four corners, you'd reduce by 75 percent the amount of time it took to make a noticeable burn.
Probably longer than 75%. Seems to me that burn-in is more a function of "length of time pixels are consistently illuminated" than "total duration that a given pixel is illuminated." Or, by your Mk I example, I'd imagine if that two months of Now & Next were spread over 2 years, I don't think there'd be any burn-in, whereas having the pixels constantly illuminated for an extended period of time is more the problem.
