v2.02 is out:
  • Changed the loop timer to try to reduce CPU utilization. The player should hopefully lag less now.
  • The method I was using for switching visuals depended on having favorite visuals set, and some people don't, so I'm trying a new way. This one uses one less button press, and seems to work on both v2 final and v3a8.
  • It's the Unix script's turn for a bugfix. Took the passive mode command out, which really shouldn't have been there. If you tried to install from a Unix box and it failed, try, try again.
As always, feedback is welcome.
