Well I finally saved all my music on the second drive, and uploaded the Reiser kernel plus tools. I used the mkresierfs tool, it seems to go fine. But if I try to write anything to the drive, the unit becomes unresponsive on the shell, and hijack shows a load of 4. Here is what I did, with the error being the last line:
sh-2.03# mkreiserfs /dev/hda4
<-----------MKREISERFS, 1999----------->
ReiserFS version 3.5.18
Block size 4096 bytes
Block count 7304848
First 16 blocks skipped
Super block is in 16
Bitmap blocks are :
17, 32768, 65536, 98304, 131072, 163840, 196608, 229376, 262144, 294912, 327680, 360448, 393216, 425984, 458752, 491520, 524288,
557056, 589824, 622592, 655360, 688128, 720896, 753664, 786432, 819200, 851968, 884736, 917504, 950272, 983040, 1015808, 1048576, 1081344
, 1114112, 1146880, 1179648, 1212416, 1245184, 1277952, 1310720, 1343488, 1376256, 1409024, 1441792, 1474560, 1507328, 1540096, 1572864,
1605632, 1638400, 1671168, 1703936, 1736704, 1769472, 1802240, 1835008, 1867776, 1900544, 1933312, 1966080, 1998848, 2031616, 2064384, 20
97152, 2129920, 2162688, 2195456, 2228224, 2260992, 2293760, 2326528, 2359296, 2392064, 2424832, 2457600, 2490368, 2523136, 2555904, 2588
672, 2621440, 2654208, 2686976, 2719744, 2752512, 2785280, 2818048, 2850816, 2883584, 2916352, 2949120, 2981888, 3014656, 3047424, 308019
2, 3112960, 3145728, 3178496, 3211264, 3244032, 3276800, 3309568, 3342336, 3375104, 3407872, 3440640, 3473408, 3506176, 3538944, 3571712,
3604480, 3637248, 3670016, 3702784, 3735552, 3768320, 3801088, 3833856, 3866624, 3899392, 3932160, 3964928, 3997696, 4030464, 4063232, 4
096000, 4128768, 4161536, 4194304, 4227072, 4259840, 4292608, 4325376, 4358144, 4390912, 4423680, 4456448, 4489216, 4521984, 4554752, 458
7520, 4620288, 4653056, 4685824, 4718592, 4751360, 4784128, 4816896, 4849664, 4882432, 4915200, 4947968, 4980736, 5013504, 5046272, 50790
40, 5111808, 5144576, 5177344, 5210112, 5242880, 5275648, 5308416, 5341184, 5373952, 5406720, 5439488, 5472256, 5505024, 5537792, 5570560
, 5603328, 5636096, 5668864, 5701632, 5734400, 5767168, 5799936, 5832704, 5865472, 5898240, 5931008, 5963776, 5996544, 6029312, 6062080,
6094848, 6127616, 6160384, 6193152, 6225920, 6258688, 6291456, 6324224, 6356992, 6389760, 6422528, 6455296, 6488064, 6520832, 6553600, 65
86368, 6619136, 6651904, 6684672, 6717440, 6750208, 6782976, 6815744, 6848512, 6881280, 6914048, 6946816, 6979584, 7012352, 7045120, 7077
888, 7110656, 7143424, 7176192, 7208960, 7241728, 7274496
Journal size 8192 (blocks 18-8210 of device 0x3:0x4)
Root block 8211
Used 8434 blocks
ATTENTION: ALL DATA WILL BE LOST ON '/dev/hda4'! (y/n)y
Initializing journal - 0%....20%....40%....60%....80%....100%
Syncing..
ReiserFS core development sponsored by SuSE Labs (suse.com)
Journaling sponsored by MP3.com.
Item handlers sponsored by Ecila.com
To learn about the programmers and ReiserFS, please go to
http://www.devlinux.com/namesys
Have fun.
sh-2.03# mount /dev/hda4 /drive0
clm-2030: reading through journal entries
clm-2036: No valid transactions found
clm-2038: Replayed 0 transactions in 13 seconds, mount_id now 10
sh-2.03# cd /drive1/musicback/
sh-2.03# tar -cplf - . | (cd /drive0 && tar xpf -)
vs-7015: linear_search_in_dir_item: item must be 0-th item in block (1)
