#287887 - 06/10/2006 15:16 broken trace on ide header
serrano1
Loc: California
does anybody know were to jumper data lines 5 and 6 of the ide header, i accidentaly lifted the solder pad and need to get a jumper to location on the empeg/riocar board, any help is greatly appreciated.
thanks in advance.
FORGOT TO INCLUDE THE BOOT LOG.
e000 v1.04
Copying kernel...
Calling linux kernel...
Linux version 2.2.17-rmk5-np17-empeg52-hijack-v461 (hijack@rtr.ca) (gcc version 2.95.3 20010315 (release)) #2 Thu Jun 8 15:00:28 EDT 2006
Checking for extra DRAM:
c1000000: wrote ffffffff, read e28cc001
empeg-car player (hardware revision 9, serial number 40104266) 16MB DRAM
Command line: mem=16m
Memory: 15008k/16M available (988k code, 20k reserved, 364k data, 4k init)
Linux NET4.0 for Linux 2.2
IP Protocols: ICMP, UDP, TCP
Starting kswapd v 1.5
Signature is 67706d65 'empg'
Found custom animation at offset 0x9877c
Tuner: loopback=0, ID=-1
Scheduling custom logo.
empeg display initialised.
empeg dsp audio initialised
empeg dsp mixer initialised
empeg dsp initialised
empeg state support initialised 0089/88c1 (save to d0004b00).
empeg RDS driver initialised
empeg single channel IDE
Probing primary interface...
ide_data_test: wrote 0x0000 read 0xff80
ide_data_test: wrote 0xffff read 0xff80
ide_data_test: wrote 0xaaaa read 0xaa80
ide_data_test: wrote 0x5555 read 0x5580
ide_data_test: wrote 0x0000 read 0xff90
ide_data_test: wrote 0xffff read 0xff90
ide_data_test: wrote 0xaaaa read 0xaa90
ide_data_test: wrote 0x5555 read 0x5590
ide_data_test: wrote 0x0000 read 0xff00
ide_data_test: wrote 0xffff read 0xff00
ide_data_test: wrote 0xaaaa read 0xaa00
ide_data_test: wrote 0x5555 read 0x5500
hda: ST9100823A, ATA DISK drive
hdb: IC25N040ATCS04-0, ATA DISK drive
hda: ST9100823A, 95396MB w/8192kB Cache, CHS=12161/255/63
hdb: IC25N040ATCS04-0, 38154MB w/1768kB Cache, CHS=4864/255/63
smc chip id/revision 0x3349
SMC9194: SMC91C94(r:9) at 0x4008000 IRQ:7 INTF:TP MEM:6144b MAC 00:02:d7:28:10:aa
Partition check:
RAMDISK: Loading 320 blocks [1 disk] into ram disk... |/-\|/-\|/-\|/-\|/-\done.
empeg-pump v0.03 (19980601)
Press Ctrl-A to enter pump... hange_root: old root has d_count=1
Mounting proc
Starting player
Timezone: America/Tijuana
Edited by serrano1 (06/10/2006 16:04)
#287888 - 08/10/2006 11:58 Re: broken trace on ide header [Re: serrano1]
maczrool
Loc: Louisiana, USA
If you mean pins 5 and 7 of the IDE header (pin 5 on the header is D6 and pin 7 is D5), try D6 to pin 9 of the 74LVX4245 nearest the right side of the Empeg board (with the screen facing you) and D5 to pin 8 of the same.
Hope this helps,
Stu
#287889 - 09/10/2006 16:31 Re: broken trace on ide header [Re: maczrool]
serrano1
Loc: California
Thanks Stu, that is the information i needed.
