#244247 - 17/12/2004 11:45
End of Playlist?
Hi,
Whenever i turn on my empeg, it always says "End of Playlist", it use to go back to the last song it was playing before. I connected the Serial cable to see if something was going on with the hdd's and i see this at the end:
cat: /drive0/var/tts/greetings.pcm: No such file or directory hijack_exec("", "exec /drive0/var/ttsclock"), rc=0 (okay) hijack: removed menu entry: "Hard Disk Detection" hijack: removed menu entry: "Serial Port Assignment" khttpd: listening on port 80 kftpd: listening on port 21 player.cpp : 385:empeg-car 2.00 2003/04/01. hda: read_intr: status=0x59 hda: read_intr: error=0x40 end_request: I/O error, dev 03:03 (hda), sector 0 hda: read_intr: status=0x59 hda: read_intr: error=0x40 end_request: I/O error, dev 03:03 (hda), sector 0 Prolux 4 empeg car - 2.1434 Mar 26 2003 Vcb: 0x4086d000 hda: read_intr: status=0x59 hda: read_intr: error=0x40 end_request: I/O error, dev 03:03 (hda), sector 0
Can anyone tell me about this error?
thanks
#244248 - 17/12/2004 11:49
Re: End of Playlist?
[Re: michael_corleone]
I didn't know if i should post the whole thing, so here it is.
empeg-car bootstrap v1.02 20001106 (hugo@empeg.com) If there is anyone present who wants to upgrade the flash, let them speak now, or forever hold their peace...it seems not. Let fly the Penguins of Linux!
e000 v1.04 Copying kernel... Calling linux kernel... Uncompressing Linux..................................... done, booting the kerne l. Linux version 2.2.17-rmk5-np17-empeg52-hijack-v395 (mark@rtr.ca) (gcc version 2. 95.3 20010315 (release)) #2 Sun Jun 27 17:52:49 EDT 2004 Processor: Intel StrongARM-1100 revision 11 Checking for extra DRAM: c1000000: wrote ffffffff, read e91ba9f0 NetWinder Floating Point Emulator V0.94.1 (c) 1998 Corel Computer Corp. empeg-car player (hardware revision 9, serial number 30102524) 16MB DRAM Command line: mem=16m Calibrating delay loop... 207.67 BogoMIPS Memory: 15016k/16M available (980k code, 20k reserved, 364k data, 4k init) Dentry hash table entries: 2048 (order 2, 16k) Buffer cache hash table entries: 16384 (order 4, 64k) Page cache hash table entries: 4096 (order 2, 16k) POSIX conformance testing by UNIFIX Linux NET4.0 for Linux 2.2 Based upon Swansea University Computer Society NET3.039 NET4: Linux TCP/IP 1.0 for NET4.0 IP Protocols: ICMP, UDP, TCP TCP: Hash tables configured (ehash 16384 bhash 16384) IrDA (tm) Protocols for Linux-2.2 (Dag Brattli) Starting kswapd v 1.5 SA1100 serial driver version 4.27 with no serial options enabled ttyS00 at 0xf8010000 (irq = 15) is a SA1100 UART ttyS01 at 0xf8050000 (irq = 17) is a SA1100 UART ttyS02 at 0xf8030000 (irq = 16) is a SA1100 UART Signature is 67706d65 'empg' Found custom animation at offset 0x9877c Tuner: loopback=0, ID=-1 Scheduling custom logo. empeg display initialised. empeg dsp audio initialised empeg dsp mixer initialised empeg dsp initialised empeg audio-in initialised, CS4231A revision a0 empeg remote control/panel button initialised. empeg usb initialised, PDIUSBD12 id 1012 empeg state support initialised 0089/88c1 (save to d0004280). empeg RDS driver initialised empeg power-pic driver initialised (first boot) RAM disk driver initialized: 16 RAM disks of 4096K size empeg single channel IDE Probing primary interface... hda: HTS548040M9AT00, ATA DISK drive hdb: HTS548040M9AT00, ATA DISK drive ide0 at 0x000-0x007,0x038 on irq 6 hda: HTS548040M9AT00, 38154MB w/7877kB Cache, CHS=4864/255/63 hdb: HTS548040M9AT00, 38154MB w/7877kB Cache, CHS=4864/255/63 empeg-flash driver initialized smc chip id/revision 0x3349 smc9194.c:v0.12 03/06/96 by Erik Stahlman (erik@vt.edu)
SMC9194: SMC91C94(r:9) at 0x4008000 IRQ:7 INTF:TP MEM:6144b MAC 00:02:d7:26:09:d c Partition check: hda: hda1 < hda5 hda6 > hda2 hda3 hda4 hdb: hdb1 < hdb5 hdb6 > hdb2 hdb3 hdb4 RAMDISK: ext2 filesystem found at block 0 RAMDISK: Loading 320 blocks [1 disk] into ram disk... done. EXT2-fs warning: checktime reached, running e2fsck is recommended VFS: Mounted root (ext2 filesystem). Timezone: /usr/share/zoneinfo empeg-pump v0.03 (19980601) Press Ctrl-A to enter pump...VFS: Mounted root (ext2 filesystem) readonly. change_root: old root has d_count=1 Trying to unmount old root ... okay Freeing unused kernel memory: 4k initempeg init 0.8 I see this is a developer image! Mounting proc Mounting first music partition Tried to mount /dev/hda4 as reiserfs but got error 19 Mounting second music partition Remounting first music partition read-only Remounting second music partition read-only Press 'q' now to go into development mode. You Have Zero Seconds To Comply... Starting player Timezone: /usr/share/zoneinfo/UTC Hijack: intercepting config.ini
Saved AC volume was 90 Volume=90 hijack_exec("", "exec /drive0/var/setvol"), rc=0 (okay) Saved AC volume was 90 Volume=90 PlaYing sAMPle 115 hijack_exec("", "exec /drive0/var/randomsound"), rc=0 (okay) Saved AC volume was 90 Volume=90 PlaYing sAMPle 38 hijack_exec("", "exec /drive0/var/randomsound"), rc=0 (okay) Using theme x with intro x 5 12 17 08 50 Saved AC volume was 90 Volume=90 /drive0/var/tts/greetings.pcm /drive0/var/tts/morning.pcm /drive0/var/tts/todayi s.pcm /drive0/var/tts/week5.pcm /drive0/var/tts/month12.pcm /drive0/var/tts/17th .pcm /drive0/var/tts/xthetimeis.pcm /drive0/var/tts/x8.pcm /drive0/var/tts/x50.p cm /drive0/var/tts/xam.pcm cat: /drive0/var/tts/greetings.pcm: No such file or directory hijack_exec("", "exec /drive0/var/ttsclock"), rc=0 (okay) hijack: removed menu entry: "Hard Disk Detection" hijack: removed menu entry: "Serial Port Assignment" khttpd: listening on port 80 kftpd: listening on port 21 player.cpp : 385:empeg-car 2.00 2003/04/01. hda: read_intr: status=0x59 hda: read_intr: error=0x40 end_request: I/O error, dev 03:03 (hda), sector 0 hda: read_intr: status=0x59 hda: read_intr: error=0x40 end_request: I/O error, dev 03:03 (hda), sector 0 Prolux 4 empeg car - 2.1434 Mar 26 2003 Vcb: 0x4086d000 hda: read_intr: status=0x59 hda: read_intr: error=0x40 end_request: I/O error, dev 03:03 (hda), sector 0
#244249 - 17/12/2004 12:03
cat: /drive0/var/tts/greetings.pcm: No such file or directory (/q] Your tts installation seems corrupt - the file greetings.pcm vcan't be located... hijack_exec("", "exec /drive0/var/ttsclock"), rc=0 (okay)
q[] hijack: removed menu entry: "Hard Disk Detection" hijack: removed menu entry: "Serial Port Assignment" khttpd: listening on port 80 kftpd: listening on port 21 player.cpp : 385:empeg-car 2.00 2003/04/01. hda: read_intr: status=0x59 hda: read_intr: error=0x40 end_request: I/O error, dev 03:03 (hda), sector 0 hda: read_intr: status=0x59 hda: read_intr: error=0x40 end_request: I/O error, dev 03:03 (hda), sector 0 Prolux 4 empeg car - 2.1434 Mar 26 2003 Vcb: 0x4086d000 hda: read_intr: status=0x59 hda: read_intr: error=0x40 end_request: I/O error, dev 03:03 (hda), sector 0 Can anyone tell me about this error?
Looks like a hardware error - check the drive cable (crimping og contacts) and the soldering of the IDE header on the mainboard. You could also try a manual fsck in case it's a corrupted file system (all well documented in the FAQ) Could also be the drive itself dying...
#244250 - 17/12/2004 13:34
I would suspect a corrupted filesystem here: do a quick FAQ for what to do.
#244251 - 17/12/2004 14:28
[Re: schofiel]
Thanks for the replys but it's weird when I Run the e2fsck Fix from the FAQ. this is what I get:
Starting bash. empeg:/empeg/bin# ro empeg:/empeg/bin# umount /dev/hda4 empeg:/empeg/bin# umount /dev/hdc4 empeg:/empeg/bin# swapon /swapfile Adding Swap: 16028k swap-space (priority -1) empeg:/empeg/bin# fsck -fay / Parallelizing fsck version 1.19 (13-Jul-2000) e2fsck 1.19, 13-Jul-2000 for EXT2 FS 0.5b, 95/08/09 ext2fs_check_if_mount: No such file or directory while determining whether /dev/ hda5 is mounted. Pass 1: Checking inodes, blocks, and sizes Pass 2: Checking directory structure Pass 3: Checking directory connectivity Pass 4: Checking reference counts Pass 5: Checking group summary information /dev/hda5: 1515/4096 files (0.5% non-contiguous), 9458/16384 blocks empeg:/empeg/bin# fsck -fay /dev/hda4 Parallelizing fsck version 1.19 (13-Jul-2000) e2fsck 1.19, 13-Jul-2000 for EXT2 FS 0.5b, 95/08/09 ext2fs_check_if_mount: No such file or directory while determining whether /dev/ hda4 is mounted. Pass 1: Checking inodes, blocks, and sizes
etc........
Why does it say no such file or directory? or am i doing something wrong?
#244252 - 17/12/2004 15:37
No, that's normal because of the nonstandard way the empeg's Linux installation is. While you my have a corrupted filesystem, I believe that the I/O errors are hardware errors and need to be corrected themselves. Could be the IDE header, the cable, or the hard drive. There's a FAQ on what to look for.
#244253 - 17/12/2004 15:44
The error is on /dev/hda3, not the one(s) you ran fsck on.
/dev/hda3 is where the player software saves a lot of settings, including the current running order (playlist) and per-track settings and stuff.
There is no fsck for /dev/hda3, but you could instead simply wipe it clean and hope that fixes the error.
Connect via serial port, hit control^C to break out of the player and get a shell (command) prompt. Then do this to wipe out /dev/hda3:
cat /dev/zero > /dev/hda3
#244254 - 17/12/2004 17:22
empeg:/empeg/bin# cat /dev/zero > /dev/hda3 cat: write error: No space left on device empeg:/empeg/bin#
i should have 9 gig left
#244255 - 17/12/2004 17:46
Quote: cat: write error: No space left on device
That's expected. The command that Mark gave you simply reads the content of /dev/zero and writes it to /dev/hda3. Since /dev/zero is an infinitely-long sequence of zeros, it'll stop when /dev/hda3 is full, giving that error.
And /dev/hda3 is only 16Mb in size, so it'll fill up quite quickly.
#244256 - 17/12/2004 18:09
yeah, like Roger said, that message was expected, and good to see.
Now cycle the power and see if it works.
#244257 - 17/12/2004 20:01
Cool that problem is gone but i still get this error
should i ignore?
thanks for all your help
#244258 - 17/12/2004 20:47
That's just a useless "warning", not an error.
Ignore it.
#244259 - 18/12/2004 19:39
an It just says that a certain time or number of mount operations has elapsed since last file systemcheck (fsck) was run on the partition. d can, IIRC, be turned off with Hijack. No worries, if something potentially truly bad happens (like forgetting to remount as read-only after having something mounted read-write) it wll stilll notice and complain. A synch will take care of the mattter, but it wlil ltake longer (with big drives potentially loooong) time as it wll then do an fsck at that time. Which is annoying as Murphy assures it will be the time whenyou just wanted to toss on a few new tracks or a few tag updates and be on your way...
#244260 - 01/02/2005 16:48
[Re: mtempsch]
i am having the same error as michael_corleone.  it turns out to be a hdd problem...bad sector. running hitachi DFT and erasing the disk. i hope it works.
#244261 - 06/02/2005 18:01
[Re: chuckcheeze]
Quote: it turns out to be a hdd problem...bad sector. running hitachi DFT and erasing the disk. i hope it works.
Keep in mind to put the drive back in the empeg, you will need to run the "Builder" image. Search the FAQ for more on this, and if you have two drives, make sure the good one is disconnected.
