Thanks. That worked to let me mount read only but emphatic still isn't showing up in the hijack menu. So here is the boot log you asked for...
empeg-car bootstrap v1.02 20001106 (hugo@empeg.com)-xr-x 4 0 0 1024 Feb 6 2000
If there is anyone present who wants to upgrade the flash, let them speak now,0 0 1024 Aug 28 1999 var............ done, booting the kern
or forever hold their peace...it seems not. Let fly the Penguins of Linux!drive-: No such file or directoryrmk5-np17-empeg52-hijack-v312 (root@ibbm)
e000 v1.04 cd /drive
Copying kernel...
empeg:/drive0#
Calling linux kernel...
total 476
.3
Processor: Intel StrongAR
drwxr-xr-x 2 0 0
l.12
Linux version 2.2.17-rmk5-np17-empeg52-hijack-v312 (root@i.94.1 (c) 1
Calibrating delay loop... 207.67 BogoMIPS 501718 Jan 13 2033 database
Memory: 14996k/16M available (992k code, 20k reserved, 372k data, 4k init) 0 18664 Jan 13 2033 playlists conformance testing by UNIFIX
Dentry hash table entries: 2048 (order 2, 16k) 1 0 0 377 Jan 13 2033 t
empeg:/drive0/var# mv emphatic /drive0/var
Page cache hash table entries: 4096 (order 2 emphatic: No such f
NET4: Linux TCP/IP 1.0 for NET4.0otocol (Dag Brattli)
empeg:/drive
IP Protocols: ICMP, UDP, TCP/drive0# mv emphatic /drive0
TCP: Hash tables configured (ehash 16384 bhash 16384)create regular file `/drive0/var/emphatic': Read-only
IrDA (tm) Protocols for Linux-2.2 (Dag Brattli)rq = 15) is a SA1100 UART
empeg:
IrCOMM protocol (Dag Brattli)
empeg:/drive0# mv emphatic /
Starting kswapd v 1.5
drwxr-xr-x 2 0 0 120832 Jan 13 2033 fidsre
ttyS00 at 0xf8010000 (irq = 15) is a SA1100 UARTund cust
drwxr-xr-x 2 0 0 12
ttyS01 at 0xf8050000 (irq = 17) is a SA1100 UARTialised.
empeg dsp
empeg RDS driver
-rw------- 1 0 0
empeg remote control/panel button initialised.(first boot)
empeg usb initialised, PDIUSBD12 id 1012 18664 Jan 13 2033 playlists
empeg state support initialised 0089/88c1 (save to d0005600).-r--r-- 1 0 0 377 Jan 13 2033 tagse...
empeg RDS driver initialisedhda: IBM-DJSA-220, ATA DISK
empeg power-pic driver initialised (first boot)x000-0x007,0x038 on irq 6
empeg:/drive0/var# l
SMC9194:
hda: IBM-DJSA-220, 19077MB w/1874kB Cache, CHS=38760/16/63 0 18664 Jan 13 2033 playlists
e
Partition ch
-rw-r--r--
smc chip id/revision 0x3349 377 Jan 13 2033 tags
smc9194.c:v0.12 03/06/96 by Erik Stahlman (erik@vt.edu)empeg:/drive0/var# ro
empeg:/drive
SMC9194: SMC91C94(r:9) at 0x4008000 IRQ:7 INTF:TP MEM:6144b MAC 00:02:d7:28:10:agout
Shell exit
Mounting proc
No secondary hard disk
Press 'q' now to go into development mode. You Have Zero Seconds ToStarting play
er
hijack_do_execve: execve() failed, errno = 2
hijack_exec("/drive0/emphatic"), rc=-2 (ERROR)
khttpd: listening on port 80
kftpd: listening on port 21
Vcb: 0x4086d000
