#112971 - 25/08/2002 20:13 DOA!
MoRoToRiUm
My empeg 2 has mysteriously stopped working! All I get is the No hard disk found; Pleas contact support with a lovely dead mandrake penguin. I ref;ashed the image just to make sure there was nothing there unplugged hardrive and reconnected everything. Still no luck. I can access the HiJack kernel options and everything except for the hard drive. Help! I don't want to loose everything!
#112972 - 25/08/2002 20:22 Re: DOA! [Re: MoRoToRiUm]
Please hook up to your empeg using a serial (null modem) cable, connect to it with a terminal program, and post the output here so we can get an idea what might be wrong.
#112973 - 25/08/2002 20:36 Re: DOA! [Re: tonyc]
MoRoToRiUm
e000 v1.04
Copying kernel...
Calling linux kernel...
Uncompressing Linux................................... done, booting the kernel.
Linux version 2.2.14-rmk5-np17-empeg51-hijack-v291 (root@tbird.localnet) (gcc version 2.95.3 20010315 (release)) #2 Wed Jul 31 10:10:42 EDT 2002
empeg-car player (hardware revision 9, serial number 10101678)
Command line: mem=16m
Memory: 15076k/16M available (928k code, 20k reserved, 356k data, 4k init)
Linux NET4.0 for Linux 2.2
IP Protocols: ICMP, UDP, TCP
Starting kswapd v 1.5
Signature is 206f6972 'rio '
Found custom animation at offset 0x9a790
empeg display initialised.
empeg dsp audio initialised
empeg dsp mixer initialised
empeg dsp initialised
empeg state support initialised 0089/88c1 (save to d0004800).
empeg RDS driver initialised
empeg single channel IDE
Probing primary interface...
smc chip id/revision 0x3349
SMC9194: SMC91C94(r:9) at 0x4008000 IRQ:7 INTF:TP MEM:6144b MAC 00:02:d7:22:06:8e
RAMDISK: Loading 320 blocks [1 disk] into ram disk... |/-\|/-\|/-\|/-\|/-\done.
empeg-pump v0.03 (19980601)
Press Ctrl-A to enter pump... VFS: Cannot open root device 03:05
Kernel panic: VFS: Unable to mount root fs
- i think my high quality IBM travelstar hardrive is dead...
#112974 - 25/08/2002 21:36 Re: DOA! [Re: MoRoToRiUm]
It's probably the HDD died or the Cable. Did you try plugging the drive into the free connector on the IDE cable.
#112975 - 26/08/2002 01:42 Re: DOA! [Re: MoRoToRiUm]
MoRoToRiUm, have you read this yet?
#112976 - 26/08/2002 09:21 Re: DOA! [Re: tfabris]
MoRoToRiUm
Once again hats off to Tony. YOU ARE GOD!
Bad IDE cable. Works fine when I have the hardrive on the second connector. Contacted support so hopefully I get a replacement for free. Thanks again!
#112977 - 26/08/2002 09:33 Re: DOA! [Re: MoRoToRiUm]
Careful, talk like that might go to my head.
Thanks, glad you're working again.
#112978 - 27/08/2002 18:35 Re: DOA! [Re: MoRoToRiUm]
genixia
...that goes contrary to popular belief here that Patrick is God. Unless you are a polytheist
