well i copyed them all and it looks like everything went good. but when it boots i think there may be something wrong.
i get this "Tried to mount /dev/hda4 as reiserfs but got error 19"
but other then that it seems to work great
thanks for the help. (if i read the FAQ)
here is the boot log
e000 v1.04
Copying kernel...
Calling linux kernel...
l.
Linux version 2.2.14-rmk5-np17-empeg51 (mac@aphex) (gcc version 2.95.3 20010315
(release)) #16 Wed Jul 24 18:19:54 BST 2002
empeg-car player (hardware revision 7, serial number 90000576)
Command line: mem=12m
Memory: 10968k/12M available (964k code, 20k reserved, 332k data, 4k init)
Linux NET4.0 for Linux 2.2
IP Protocols: ICMP, UDP, TCP
Starting kswapd v 1.5
Signature is ffffffff 'ÿÿÿÿ'
empeg display initialised.
empeg dsp audio initialised
empeg dsp mixer initialised
empeg dsp initialised
empeg state support initialised 0089/88c1 (save to d0005a00).
empeg RDS driver initialised
empeg single channel IDE
Probing primary interface...
hda: IC25T060ATCS05-0, ATA DISK drive
hdb: IC25T060ATCS05-0, ATA DISK drive
hda: IC25T060ATCS05-0, 57231MB w/1768kB Cache, CHS=7296/255/63
hdb: IC25T060ATCS05-0, 57231MB w/1768kB Cache, CHS=7296/255/63
smc chip id/revision 0x3349
SMC9194: SMC91C94(r:9) at 0x4008000 IRQ:7 INTF:TP MEM:6144b MAC 00:02:d7:12:02:4
0
Partition check:
empeg-pump v0.03 (19980601)
Press Ctrl-A to enter pump...adonly.
Mounting proc
Starting player
Vcb: 0x40576000
