Mark,
I did delete all the empegweb Files on my Empeg. And then the HTTP and FTP Connection to my Empeg is working (Hijack V130). But If I go to install the latest version 1.2 or 1.3 from empegweb it does not work.
This means: I did the change the IP-Address in the index.html from 192.168.0.2 to 10.0.1.10. And then It doen't work. I did try to browse empegweb on my local machine. Not on the Empeg. But the same problem is also on the Empeg. I did only try to get out where excactly the problem is. If I go and change the IP-Address back to 192.168.0.2 then I can browse it locally again.
So I thinks there is a little problem in the Empegweb application.
crazymelki.com
