I can connect to the empeg through the network (w/ DHCP server) when another drive is drive 0, but when I add this new drive as drive 1, I can no longer access it! It doesn't make sense.
Don't take offense, but are you sure about which drive is getting mounted where? It sure sounds like your new drive is coming up as master (drive0) and the old drive as slave (drive1). I'd triple check the jumpers and watch the boot output over serial to be sure.
-Mike
EmpMenuX - ext3 filesystem - Empeg iTunes integration
