I am currently running Hijack 440 modded for ext3
Do you reservecache set in your config.ini? If not try adding it with a smallish value (try 10 or 20). I'm guessing it is the OS not the player software running out of memory since the ext3 support takes a little more memory than a stock config.
-Mike
EmpMenuX - ext3 filesystem - Empeg iTunes integration
