Here's teh second log file. This one is the one that Stuart tried to replace the chip on. Well, he did really but it still doesn't work. This one is a spare unit.
e000 v1.04
Copying kern
Calling linux kernel...
l.
Linux version 2.2.14-rmk5-np17-empeg51 (mac@aphex) (gcc version 2.95.3 20010315
(release)) #17 Wed Jul 24 18:23:20 BST 2002
empeg-car player (hardware revision 9, serial number 10101594)
Command line: mem=16m
Memory: 15024k/16M available (964k code, 2
Linux NET4.0 for Linux 2.2
IP Protocols: ICMP, UDP, TCP
Starting kswapd v 1.5
Signature is 206f6972 'rio '
empeg display initialised.
empeg dsp audio initialised
i2c: Failed to receive ACK for data!
i2c_write: device select failed
I2C write failed (fff, d223)
I2C write failed (927, 0)
I2C write failed (8f9, 90d)
I2C write failed (8ef, 800)
empeg dsp mixer in
empeg dsp initialised
Could not find CS4231A (version=81)
empeg state support initialised 0089/88c1 (save to d0005400).
empeg RDS driver initialised
empeg single channel IDE
Probing primary interface...
smc chip id/revision 0x3349
SMC9194: SMC91C94(r:9) at 0x4008000 IRQ:7 INTF:TP MEM:6144b MAC 00:02:d7:22:06:3
a
empeg-pump v0.03 (19980601)
Press Ctrl-A to enter pump...VFS: Cannot open root device 03:05
Kernel panic: VFS: Unable to mount root fs on 03:05
