Alright, I've reconfig'd the Empeg to use DHCP and tried it here at work and it still connects... good. However, it also is still using IP address 192.168.0.45. Is this a coinceidence? I have removed the info from the Empeg that had that IP so is there something burried in the player that would make it use that address if given the opportunity?
Also, give me some clue where to start when reprogramming my cable router to dole out IP's in the 192.168.0.xxx range. That seems like the way I'd rather go so that I can run a fixed IP on my Empeg.
Bodybag - So Cal
Not a Whiner any more!!!
