#98480 - 09/06/2002 19:17 Two head units, EMPEG as slave - best ways to wire
alarosa
I'm gonna be installing my 20 gig EMPEG into my Subaru Impreza (2001, 2.5RS coupe), along with a Pioneer DEH-7400 unit for XM radio/CDs. What I'm planning on doing is using the EMPEG as a slave to the Pioneer so I can utilize the Pioneer's subwoofer-level preamp outputs no matter what source I have for the audio. Of course, the 7400 only has two channels for its AUX inputs. What I'm planning on doing is bridging the Front/Rear Left outs and the Front/Rear Right outputs together, so I will essentially only have L/R outputs for the EMPEG. Anyone know what the best hardware for bridging the channels would be, or if there's a better way to accomplish this kind of setup?
#98481 - 09/06/2002 21:07 Re: Two head units, EMPEG as slave - best ways to wire [Re: alarosa]
You do not want to bridge the F/R outputs of the empeg. Strange things will happen if you do that -- you only want to bridge them through some sort of switcher.
There is no need to bridge the F/R outputs in any case -- they are identical, unless you have the fader on the empeg set to something other than "Center" or if you have your equalizer set up for 4-channel operation.
Just run your front outputs of the empeg into the auxiliiary inputs of the Pioneer and you will be set. Remember that you will be able to use the empeg's 20 band equalizer, volume settings, and left/right balance controls on the signal you feed into the Pioneer.
#98482 - 09/06/2002 21:44 Re: Two head units, EMPEG as slave - best ways to wire [Re: alarosa]
Right, what Doug said. Connect only the front outputs from the empeg into the Aux-in of the Pioneer.
This is the way all Aux Inputs work, always have. There's even a picture of it in the FAQ, which I would link you to if it weren't for the fact that riocar.org is down at the moment.
#98483 - 09/06/2002 22:09 Re: Two head units, EMPEG as slave - best ways to wire [Re: tfabris]
alarosa
Awesome, thanks for the info :-)
#98484 - 10/06/2002 00:44 Re: Two head units, EMPEG as slave - best ways to [Re: alarosa]
juenk
Loc: Waardenburg, The Netherlands
Reading the PH-7400 specs , you'll probably need a Pioneer RB-20 addon in order to use the AUX functionality.
Jelle
Empeg M2A Blue # 010101908 80Gb
Empeg M2A Blue # 030102771 with backlight buttons - Need repair (IDE cable connection on main board) - volunteers?
#98485 - 10/06/2002 10:15 Re: Two head units, EMPEG as slave - best ways to [Re: juenk]
Or a Pioneer CD-RB10, which is about $40 cheaper, but does not have the pass through for a CD changer (who needs one when you have an empeg anyway?)
