#97700 - 05/06/2002 13:01 Stack trace problem - HiJack kernel
tarkie
I know that this isnt the most recent HiJack, and I shall be upgrading once I've posted this, but it could lead Mark to find a problem that has been carried forward.
I was sync'ing a few hundred tracks onto the player via ethernet when they all failed being unable to contact the player - as it had crashed.
Copying kernel...
Calling linux kernel...
Uncompressing Linux...................................... done, booting the kern
el.
Linux version 2.2.14-rmk5-np17-empeg50-hijack-v246 (root@tbird.localnet) (gcc ve
rsion 2.95.3 20010315 (release)) #2 Mon Mar 18 10:32:16 EST 2002
empeg-car player (hardware revision 9, serial number 30103088)
Command line: mem=16m
Memory: 14984k/16M available (1012k code, 20k reserved, 364k data, 4k init)
Linux NET4.0 for Linux 2.2
IP Protocols: ICMP, UDP, TCP
Starting kswapd v 1.5
Signature is 67706d65 'empg'
Found custom animation at offset 0x9bb88
Scheduling custom logo.
empeg display initialised.
empeg dsp audio i
empeg dsp mixer initialised
empeg dsp initialised
empeg state support initialised 0089/88c1 (save to d0005800).
empeg RDS driver initialised
empeg single channel IDE
Probing primary interface...
hdb: IC25N030ATCS04-0, ATA DISK drive
hda: FUJITSU MHL2300AT, ATA DISK drive
hda: FUJITSU MHL2300AT, 28615MB w/2048kB Cache, CHS=58140/16/63
hdb: IC25N030ATCS04-0, 28615MB w/1768kB Cache, CHS=58140/16/63
smc chip id/revision 0x3349
SMC9194: SMC91C94(r:9) at 0x4008000 IRQ:7 INTF:TP MEM:6144b MAC 00:02:d7:26:0c:1
0
Partition check:
RAMDISK: ext2 filesyste
empeg-pump v0.03 (19980601)
Mounting proc
Remounting first music partiti
Starting player
khttpd: listening on port 80
kftpd: listening on port 21
player.cpp : 385:empeg-car 2.00-beta11 2002/02/08.
! tags.cpp : 61:Failed to open tags (0xc0041002).
Prolux 4 empeg car - 2.1434 Feb 7 2002
Vcb: 0x4086d000
hijack_tone_init completed.
Adding Swap: 16596k swap-space (priority -1)
e2fsck 1.19, 13-Jul-2000 for EXT2 FS 0.5b, 95/08/09
hda4 is mounted.
hdc4 is mounted.
Restored terminal settings
Abnormal player termination
Player received signal 11
Starting player
Vcb: 0x4086d000
! mp3_decoder.cpp :1049:Failed to find valid sync after seeking to offset 5539
550, error=0xc0044000
Adding Swap: 16596k swap-space (priority -2)
hda4 is mounted.
hdc4 is mounted.
Starting player
Vcb: 0x4086d000
! mp3_decoder.cpp :1049:Failed to find valid sync after seeking to offset 3806
71, error=0xc0044000
Adding Swap: 16596k swap-space (priority -3)
hda4 is mounted.
hdc4 is mounted.
Unable to handle kernel paging request at virtual address c10006f8
memmap = C0F60000, pgd = c0f60000
*pgd = 00000000, *pmd = 00000000
Internal error: Oops: 2
CPU: 0
pc : [<c00456b8>] lr : [<c0044cec>]
sp : c0835e18 ip : 00000007 fp : 00000000
r10: 00802001 r9 : c0
r7 : 00000407 r6 : c0fff600 r5 : c07b5cb0 r4 : 00000005
r3 : c0fff6dc r2 : 20000000 r1 : 00000def r0 : c06808e0
Flags: nZCv IRQs on FIQs on Mode SVC_32 Segment user
Control: C0F6117D Table: C0F6117D DAC: 00000015
Process player (pid: 56, stackpage=c0835000)
Stack:
c0835e00: c0044cec c00456b8 60000013 ffffffff c00c0630 c0fff6
30
c0835e20: c07e1400 c07b5db0 c07b5db4 c01f24a0 c09b2c20 00802001 c07b5cb0 c0835e
ec
c0835e40: 00802001 c07b5d4c 00000000 00000000 c0047fc4 c0835eec fffffff
b0
c0835e60: 00000000 c00482c0 00000002 00000001 00000100 c07b5cb0 00000000 000000
00
c0835e80: c0835eec 00000008 00000001 c004871c c0835eec c0078af8 c01f7e34 000000
10
c0835ea0: c07b5cfc 00000400 ffffffea c07b5cb0 400cc000 00000059 00000000 c00468
2c
c0835ec0: c0014780 c0835eec 00000000 00000000 c0fff600 00000000 00000000 000000
00
c0835ee0: c0f983f4 c0f983e0 be1fbb4f ffffffe4 0000005f 000005b4 00000000 ffffff
ff
c0835f00: c0835f6c 0000005f c01f7d00 c0835f6c 0000005f 0000005f 0000005f 000000
00
c0835f20: be1fbaf0 c007bdf8 c0085468 00000000 c0835f3c c07c6d5c c005f1a8 000000
38
c0835f40: 00000000 00000000 00000000 00000000 be1fbaf0 c0f98380 ffffffea 000000
00
c0835f60: c005f3cc be1fbaf0 0000005f 00000000 c07b5cfc c0f983e0 ffffffea 000000
00
c0835f80: 00000059 00000000 400cc000 c002fa44 c0835f9c c0f983e0 0000002e c000a1
08
c0835fa0: 00000004 c0834000 c0835ff4 400cc000 c0009f60 0000002e 0000002e 400cc0
00
c0835fc0: 00000059 00000000 0000002e 400cc000 00000059 0216f5c8 be1ffb90 000000
00
c0835fe0: 400cc000 be1ffb88 be1ffb6c be1ffb6c 020b29b8 020e1f24 60000010 000000
2e
Backtrace: no frame pointer
Code: 1a000007 e28630dc (e7932107) e3520000 0a000003
M2a/Smoke/60gb/Tuner!! Thanks Joe M2a/Blue10gb Thanks Ian!
#97701 - 05/06/2002 13:55 Re: Stack trace problem - HiJack kernel [Re: tarkie]
BAKup
Loc: Houston, TX
It's probally the issue that was fixed in 263 when he turned hte frame pointers back on. It's the exact same issue that I and several other people on here had.
Upgrade to the latest, and that'll probally fix it.
--Ben
78GB MkIIa, Dead tuner.
#97702 - 05/06/2002 16:51 Re: Stack trace problem - HiJack kernel [Re: tarkie]
Mmm.. that crash was our good old friend "ext2_new_block()", which others have also seen from time to time.
This probably won't happen with the newest Hijack kernels, as I've turned on "frame pointer" support in those again, and others have reported that their crashes disappeared after doing that.
#97703 - 06/06/2002 11:57 Re: Stack trace problem - HiJack kernel [Re: mlord]
tarkie
Thanks Mark, it was a 'just in case' posting. No problems since going to 271.
