#97493 - 04/06/2002 12:10 Help my Rio Car is stuck!
jcp7620
The other day I was testing out a new mp3 encoder and I put one of the test files on my Rio Car. When I tried to play the file in the car the player refused to play the file and stopped responding to all input. The display indicates that it is on the track but it does not play, it just sits there and does nothing. After a few minutes it seems to go through what looks like something of a partial reboot or something and then right back to the nonworking file. I tried to connect to the player via emplode both on a serial and USB but emplode will not see the player. I was able to connect using my other player so I think that I'm doing everything correct there. I was able to upgrade the software but that did not help. I was able to connect with hyperterminal and I have pasted the output of that below, looking at the terminal output it seems that the player is in some sort of loop. I suspect that if I were to remove that file, or at least be able to keep the player from going right to it after it boots all would be fine, but I'm no Linux expert and I'm not really sure what to do. Any help would be greatly appreciated.
Thanks in advance
Here is what I copied over from hyperterminal:
e000 v1.03
Copying kernel...
Calling linux kernel...
Uncompressing Linux................................... done, booting the kernel.
Linux version 2.2.14-rmk5-np17-empeg43 (mac@aphex.internal.empeg.com) (gcc versi
on 2.95.2 19991024 (release)) #214 Sat Jun 23 16:38:57 BST 2001
empeg-car player (hardware revision 9, serial number 40103310)
Command line: mem=16m temp=33
Memory: 15064k/16M available (960k code, 20k reserved, 332k data, 8k init)
Linux NET4.0 for Linux 2.2
IP Protocols: ICMP, UDP, TCP
Starting kswapd v 1.5
Signature is 206f6972 'rio '
empeg display initialised.
empeg dsp audio initialised
empeg dsp mixer initialised
empeg dsp initialised
empeg state support initialised 0089/88c1 (save to d0005480).
empeg RDS driver initialised
empeg single channel IDE
Probing primary interface...
hda: FUJITSU MHM2200AT, ATA DISK drive
hda: FUJITSU MHM2200AT, 19077MB w/2048kB Cache, CHS=38760/16/63
smc chip id/revision 0x3349
SMC9194: SMC91C94(r:9) at 0x4008000 IRQ:7 INTF:TP MEM:6144b MAC 00:02:d7:28:0c:e
e
Partition check:
empeg-pump v0.03 (19980601)
Freeing unused kernel memory: 8k initempeg-car 1.03.
00c2f37b DHCP Our mac is 00:02:d7:28:0c:ee
00c2f37b DHCP Our address is 255.255.255.255
00c2f37b DHCP Broadcast address is 255.255.255.255
00c2f37b DHCP Current IP address is 255.255.255.255
00c2f37b DHCP Sending DHCP discover
00c2f37c DHCP Sending DHCP discover
Shell exit
empeg-car 1.03.
00c2f395 DHCP Our mac is 00:02:d7:28:0c:ee
00c2f395 DHCP Our address is 255.255.255.255
00c2f395 DHCP Broadcast address is 255.255.255.255
00c2f395 DHCP Current IP address is 255.255.255.255
00c2f395 DHCP Sending DHCP discover
Shell exit
empeg-car 1.03.
00c2f3ad DHCP Our mac is 00:02:d7:28:0c:ee
00c2f3ad DHCP Our address is 255.255.255.255
00c2f3ad DHCP Broadcast address is 255.255.255.255
00c2f3ad DHCP Current IP address is 255.255.255.255
00c2f3ad DHCP Sending DHCP discover
#97494 - 04/06/2002 12:18 Re: Help my Rio Car is stuck! [Re: jcp7620]
mtempsch
Check out the thread with this post that shows how to clear the current state.
#97495 - 04/06/2002 12:18 Re: Help my Rio Car is stuck! [Re: jcp7620]
This is a FAQ Entry.
Bam.
After you get it working again, check and see if the file also fails on version 2.0 software (I see you are running version 1.03). If the file also fails on version 2.0, you might want to hang on to it in case the empeg guys want to see it. They would like to make sure their new decoding engine doesn't crash on otherwise-good files.
#97496 - 04/06/2002 13:27 Re: Help my Rio Car is stuck! [Re: tfabris]
jcp7620
Sweet! It works! Thanks for the help guys. Sorry I didnt see it in the FAQ, I thought that I had read it all but I guess that I over looked it.
BTW the file does indeed work in 2.0
#97497 - 04/06/2002 18:06 Re: Help my Rio Car is stuck! [Re: tfabris]
maczrool
Loc: Louisiana, USA
I would love a new, less finicky decoding engine. I have several files that play fine in everything else but my RioCar.
Stu
#97498 - 04/06/2002 18:30 Re: Help my Rio Car is stuck! [Re: maczrool]
Well, if you're running 2.0, then you already have the new, less finicky decoding engine.
The files that won't play... Have you checked them out using these tools? Are the files actually good files?
#97499 - 05/06/2002 09:31 Re: Help my Rio Car is stuck! [Re: tfabris]
maczrool
Loc: Louisiana, USA
Yes, I am running 2.0b11, but I have not tried the tools. I guess I just thought that if the files played without incident on other software that the same could be said for my Rio. I will run the offending files through the tools referenced in the FAQ. Thanks.
Stu
