http://www.haloeight.net/digitronic/
It is called the Digitronic player. A friend of mine just contacted the author with some feature suggestions, so some work may follow.
Some cool features:
1. Very low CPU usage so you can listen to music while encoding
2. Support Winamp Skins if you want.
3. Stays out of the way.. (task bar if you prefer).
4. If you use IRC, it has a DDE feature that allows you to post "SE_Sport_Driver is listening to "The Pixies / Here Comes You Man". And you can customize that.
There are features it is missing, but changes are on the way. I just like its low CPU usage the most.
