#93154 - 12/05/2002 07:37 Pioneer remote control
BREmpeg
Hi people,
I bought a Pioneer CD-SR90 remote control. It's the same design of the CD-SR77/80. I used the IR translation to see the codes and put them in the Config. The problem is that I can't make the hold works. It only works pressing and releasing the buttons. I tried put .L on the two sides: xxxxxxx.L=yyyyyy.L. Tried put .L entries first. Does someone have eny tips?
Thanks in advance,
Ricardo
#93155 - 13/05/2002 04:35 Re: Pioneer remote control [Re: BREmpeg]
thinfourth2
the timing of how long you push the button has to be good so play around with the remote you should get it eventually.
#93156 - 13/05/2002 11:08 Re: Pioneer remote control [Re: BREmpeg]
I found that because the path between the empeg ir eye and the remote was partially obscured (partly because my car is RHD). This would upset the timing of the remote. If I held the remote directly in front of the empeg and used a button programmed with the long suffix it would work. In the end I gave up on the long setting...
