#93096 - 11/05/2002 18:01 Inserting playlists
Crisplinen
Is there any way to make it so that when you select a playlist or a song from a playlist using the buttons (and not the remote) on the empeg, the song or playlist you select is inserted or added to your current playlist, rather than replacing the whole list? I know it can be done using the search with the remote, but is there a way to toggle between insert/replace/append when selecting playlists?
#93097 - 11/05/2002 18:25 Re: Inserting playlists [Re: Crisplinen]
Must be using the 2.0 software...
When you are in the playlists menu, and the highlight is on a specific playlist...
Press AND HOLD the bottom button on the faceplate. You will get the insert/append/replace menu.
Enjoy!
#93098 - 11/05/2002 21:42 Re: Inserting playlists [Re: tfabris]
....Or press and hold the OK button on the remote.
#93099 - 12/05/2002 08:08 Re: Inserting playlists [Re: Shonky]
He specifically said NOT using the remote.
#93100 - 12/05/2002 16:34 Re: Inserting playlists [Re: tfabris]
OK, I'll shut up then. Once again Tony you are completely correct. Typifies my whole weekend basically.
