#91749 - 02/05/2002 17:45 New SB drive cable - No Boot/power up
Happy Birthday Micman2b
Loc: Central, NC, USA
I received a new drive cable frrom David a few weeks ago. I finally attached it this eve. After install, the player does not power up, in the car or using the wall plug. I doublechecked and finally reinstalled the old cable. After reinstalling old drive cable now the player is functional.
Any idea what may cause this? another bad cable? I should at least get a "no drive" error.. correct?
David, I will be contacting you tomorrow via emails I guess..
_____________
Sean in NC
130gb MK2a w/ 32mb ram
80gb MK2a empeg spare
#91750 - 02/05/2002 18:00 Re: New SB drive cable - No power [Re: Micman2b]
It is surprisingly easy to plug the cable into the disk drive offset by one pin. If you do this, it won't cause any damage -- but your disk drive won't spin up.
#91751 - 02/05/2002 18:03 Re: New SB drive cable - No power [Re: tanstaafl.]
duplicate post...
_____________
Sean in NC
#91752 - 02/05/2002 18:04 Re: New SB drive cable - No power [Re: tanstaafl.]
I doublechecked that. It was exactly as I removed it. All pins lined up correctly.
_____________
Sean in NC
#91753 - 02/05/2002 18:19 Re: New SB drive cable - No power [Re: tanstaafl.]
If you plug in a laptop HD cable wrong by 1 pin then it can fry something expensive. A collegue did this and blew a bunch of fuses on a motherboard because 5V and ground ended up swapped over.
The power is right at the end of the connector and can be easily wired wrong if the connector isn't aligned.
I've plugged a desktop IDE drive in with the cable in backwards once though. It just refused to start up but once I swapped it over it worked fine. Teach me to not have proper cables with the key.
- Trevor
#91754 - 02/05/2002 18:21 Re: New SB drive cable - No power [Re: Micman2b]
What happens if you unplug the HD?
If everything is working okay then it should start up and give the no HD message.
- Trevor
#91755 - 02/05/2002 18:51 Re: New SB drive cable - No power [Re: tman]
I did not try to disconnect cabling from the board as I did not want to fry anything. The empeg was acting like ther was no supplied power to the board at all...
I did not plug in correctly. There is only one way to plug it in, correctly..
I have an email into David.
_____________
Sean in NC
#91756 - 03/05/2002 01:31 Re: New SB drive cable - No power [Re: Micman2b]
Silly question, but you didn't plug it in 180 degrees reversed? That gives the "dead unit" syndrome as the PSU can't start up. It's quite easy to do when you're testing cables and have the drive tray out of the unit, I've done it several times...
#91757 - 03/05/2002 02:12 Re: New SB drive cable - No power [Re: tman]
jane
Loc: Copenhagen SW, Denmark
I actually plugged a 2 1/2" SCSI-drive into an IDE connector (Yes, such drives exist and they use the same connector.)
This destroyed and made black marks on quite a lot of different things. Motherboard, IDE-controller, and there was a big "bump" on the drive itself.
Marius (Escort Cab + Mark II)
#91758 - 03/05/2002 09:35 Re: New SB drive cable - No power [Re: Micman2b]
TheTwin314
Loc: Kansas
this exact same thing happened to me when I swapped cables, turns out I did have the cable offset by one pin on one of the connections, double, triple, quadruple check it.
eli
Empeg 50gig MkIIa (stolen :'(, my baby) In an Impreza 2.5 RS-T -also (new additions to the family)- Empeg 10gig MkIIa Empeg 50gig MkIIa
#91759 - 03/05/2002 09:41 Re: New SB drive cable - No power [Re: TheTwin314]
SE_Sport_Driver
And it may LOOK like it is securely attached to the board... press down on it again to make sure.
#91760 - 04/05/2002 18:40 Re: New SB drive cable - No power [Re: SE_Sport_Driver]
I think this may have been the problem. I rechecked the connections and even though all of the connections were correct I must have not pushed the connectors on all the way. (or I lucked out after f%cking with it enough) .
Now all seems to be functional, and better than before.
_____________
Sean in NC
#91761 - 05/05/2002 12:04 Re: New SB drive cable - No power [Re: Micman2b]
SE_Sport_Driver
Sweet!
