#89333 - 19/04/2002 11:38 Config.ini problem!
oliver
Hi, i went to look at my config.ini and the only thing in it is
; ??? ÿû°l
How can i fix this?
#89334 - 19/04/2002 12:06 Re: Config.ini problem! [Re: oliver]
This is not the first report of this, but it's been quite a while. Are you running an older beta, perchance?
Regardless, you're going to need to delete your config.ini and start over, if memory serves me correctly. Someone else is going to have to give details on that, as I don't remember if there's a better way than having to get to a shell on the empeg itself or not.
#89335 - 19/04/2002 12:08 Re: Config.ini problem! [Re: oliver]
Details in the FAQ, here.
#89336 - 19/04/2002 12:14 Re: Config.ini problem! [Re: tfabris]
Dammit. So this is the one time you put a bug-related thing in the FAQ, huh? Dammit! I was gonna go look there, but then I was like ``Nah. Tony doesn't put bugs in the FAQ.''
Oh, well.
#89337 - 19/04/2002 12:24 Re: Config.ini problem! [Re: tfabris]
oliver
Thanks Tony!
Loading the developer image onto my player right now! Hopefully it fixes the problem!
#89338 - 19/04/2002 12:24 Re: Config.ini problem! [Re: wfaulk]
oliver
I am running beta 11, with hijack 258
#89339 - 19/04/2002 12:47 Re: Config.ini problem! [Re: tfabris]
oliver
Hi Tony,
I just finished those instructions on the faqs. Now my config.ini is blank. is this normal?
#89340 - 19/04/2002 13:47 Re: Config.ini problem! [Re: oliver]
Config.ini will be blank until the next time you change the configuration in the "Configure player" screen in emplode. Fill in your personal details and stuff and synch once, and it'll no longer be blank. (You skipped step 5.)
And Bitt: You're right, I generally avoid putting specific-version-bugs in the FAQ, but I thought that one was important enough to include until the next beta is out.
