#85813 - 06/04/2002 15:13 Do I need the dimmer fix?
fusto
Loc: Lummi Island, WA
Just got my display board back from mlord with the button kit installed. And after putting it all back together and playing with it, I noticed that the button led's flicker every time I press a button or turn the knob.
Its especially noticeable if I use hijack to set the buttons at a lower lightness level.
Just wondering if this is a natural by-product of the button hack, or a sign that I need the dimmer fix.
It's a mk2a.
Selah,
Z~
I also just realized that I haven't had any of the other symptoms that would point to the dimmer fix. At least not that I ever noticed. The screen doesnt flicker during dimmer settings, but sometimed the dimmer setting and the actual brightness dont match. Thats about it though.
Edited by fusto (06/04/2002 16:49)
#85814 - 07/04/2002 12:39 Re: Do I need the dimmer fix? [Re: fusto]
Yes, the knob LEDs will flicker when you do certain things on the front panel. This is normal behavior and does not indicate a problem.
Brian, I think you should put that on your page describing the button hack if it's not there already.
#85815 - 07/04/2002 19:51 Re: Do I need the dimmer fix? [Re: tfabris]
muzza
Why does it happen?
Just interested
#85816 - 08/04/2002 02:44 Re: Do I need the dimmer fix? [Re: muzza]
smu
Loc: Germany (Ruhrgebiet)
Hi Muzza.
As far as I understand it, this happens as a result of a timing problem. The controller for the buttons is the same chip that also controlls the backlight LEDs. When a button is pressed, any other task this controller is, well, controlling gets delayed. And as the leds' brightness level is controlled using a pulse length modulation, a button press leads to a flicker of the led.
cu,
sven
#85817 - 10/04/2002 07:26 Re: Do I need the dimmer fix? [Re: smu]
lopan
Loc: Manassas VA
I thought they were supposed to do that and actually like that "feature"
Brett 60Gb MK2a with Led's
#85818 - 10/04/2002 11:03 Re: Do I need the dimmer fix? [Re: tfabris]
bmihulka
Loc: Lincoln, NE
Will do, and SMU's description is dead on.
Brian
-See my empeg <a href="www.hulkster.net/empeg" target="_blank">here</a>-
