#77769 - 04/03/2002 22:17 10 for the front 10 for the back
dcosta
Loc: Massachussetts
I'd like to be able to use 2 channel mode in a slightly different way.
I'd like to have a 10 band eq for the front and a 10 band eq for the rear.
This makes more sense to me than a 10-band for the left and a 10-band for the right because left and right speakers in the car usually match, whereas front and rear speakers usually do not.
This raises the "I wish there were 3 outputs" concern because if you cut out the low pass stuff for your fronts and rears, then there's no signal for your subs. Any way to get a third set of "non-fading" outputs for sub woofers?
what about the set on the unit itself, can we hack into those,
I know this is a stretch, but we've got illuminated button add-ons, how about third output add-ons ? Anyone ?
__________ davecosta Hijacked 60GB MKIIa 2.0b13
#77770 - 05/03/2002 00:29 Re: 10 for the front 10 for the back [Re: dcosta]
mtempsch
IIRC you can already do that, you can choose if you want to lock front/rear or left/right together (or keep them all separate for 4x5 bands). Haven't got my empeg here to play with right now though...
#77771 - 05/03/2002 11:01 Re: 10 for the front 10 for the back [Re: dcosta]
You cannot do 10 front and 10 rear.
This is a limitation of DSP chip, not a limitation of the player software. There is no way to "trick" or "work around" this limitation of the DSP in software.
The only option the DSP gives us is 5 front and 5 rear, or 10 left and 10 right. Sorry.
#77772 - 05/03/2002 11:56 Re: 10 for the front 10 for the back [Re: tfabris]
mtempsch
Aha... my misunderstanding - haven't had any reason to play with that myself...
