#7431 - 15/01/2000 11:20 Volume quiet after swap
(This message is being cross-posted to both the BBS and bugs@empeg.com.)
When I first installed the Beta 9 software (I have installed only consumer build so far) and listened to the unit on my home system, everything was fine. The new beep feature is neat.
Then I wanted to test the home/car EQ settings. So I took it to the car and played with the EQ and saved it. Then I took it back inside and plugged it into my home system.
Now the volume is really quiet in the home system. When I adjust the volume, it shows that it's at the maximum. I can even push it to +10db overdrive, and it's still really quiet compared to what it was before I took it out to the car.
#7432 - 15/01/2000 11:48 Re: Nevermind about the volume thing... [Re: tfabris]
The volume thing was my fault. I was adjusting the fader to EQ the rear speakers differently, and hadn't set it back.
Boy do I feel stupid.
Might be worth a suggestion, though: Always set the fader in the middle if it's plugged in at home?
