#68139 - 07/02/2002 04:29 Player locks up on starting audio...
Every so often my player locks up when I select the Aux input. Restarting the player does nothing even re-flashing 2.0b7 doesn't do anything. The only way to save my player is to load 1.03 and back to 2.0b7. I noticed another thread describing the exact problem:
http://empeg.comms.net/php/showthreaded.php?Cat=&Board=bigs&Number=42349&page=0&view=collapsed&sb=5&o=7
But the trail went cold and I have no idea wether the problem was solved or not. Could someone please help as its annoying in the extreme to have to re-flash the player every time this happens.
#68140 - 07/02/2002 11:43 Re: Player locks up on starting audio... [Re: andym]
See if you get the error message about "Could not find CS4231A" in the boot log. If so, e-mail support. Let us know how it goes.
#68141 - 07/02/2002 13:51 Re: Player locks up on starting audio... [Re: tfabris]
Here's the latest startup dump:
e000 v1.04
Copying kernel...
Calling linux kernel...
l.
Linux version 2.2.14-rmk5-np17-empeg50 (mac@aphex.internal.empeg.com) (gcc versi
on 2.95.3 20010315 (release)) #5 Sat Dec 22 10:18:24 GMT 2001
empeg-car player (hardware revision 9, serial number 40104298)
Command line: mem=16m
Linux NET4.0 for Linux 2.2
IP Protocols: ICMP, UDP, TCP
Starting kswapd v 1.5
Signature is 67706d65 'empg'
Scheduling custom logo.
empeg display initialised.
empeg dsp audio initialised
empeg dsp mixer initialised
empeg dsp initialised
Could not find CS4231A (version=80)
empeg state support initialised 0089/88c1 (save to d0004600).
empeg RDS driver initialised
empeg single channel IDE
Probing primary interface...
hda: FUJITSU MHM2100AT, ATA DISK drive
hda: FUJITSU MHM2100AT, 9590MB w/2048kB Cache, CHS=19485/16/63
smc chip id/revision 0x3349
SMC9194: SMC91C94(r:9) at 0x4008000 IRQ:7 INTF:TP MEM:6144b MAC 00:02:d7:28:10:c
a
Partition check:
empeg-pump v0.03 (19980601)
change_root: old root has d_count player.cpp : 550:empeg-car 2.00-beta7
(internal) 2001/12/22.
Does this mean my player is screwed?
#68142 - 07/02/2002 14:00 Re: Player locks up on starting audio... [Re: andym]
I don't know. Contact carsupport@riohome.com and see what they have to say.
#68143 - 07/02/2002 22:29 Re: Player locks up on starting audio... [Re: andym]
jwickis
Loc: India
My recently aquired Rio-car was exhibiting this same kind of behavior, I contacted support. The player seemed fine when v1.03 was on it except it would never keep time when unplugged, I could reinstall 2.0b7 only after reinstalling 1.03 first, if I tried reinstalling 2.0b7 first it would freeze during boot at 'starting audio'. When I did get a successful 2.0b7 install it would run OK (clock still wouldn't keep time) until pressing 'source' button on remote that would freeze it up again.
The problem turned out to be a chip like the other thread you mentioned in your post. Contact repair guys and get it running, it took mine just a week round trip to get back to me & they paid for the trip. Hope you find out what it is and can use it as it was intended, I was fortunate that I had my old empeg to use while the new one was at the hospital.
Edited by jwickis (07/02/2002 22:51)
#68144 - 08/02/2002 05:26 Re: Player locks up on starting audio... [Re: tfabris]
JimKnopf
Loc: Germany
Any idea how much this repair will cost? This happens not that often and my Empeg is not under warranty anymore (and I installed a hd )
#68145 - 08/02/2002 05:47 Re: Player locks up on starting audio... [Re: JimKnopf]
If I get mine fixed I'll ask how much it would cost outside the warranty.
