#5945 - 07/09/1999 15:28 Random playlist
How about a random function like many CD players have that would select and play random tracks? Maybe two versions - one that would select only from the playlist, the other that would look at the whole disk.
#5946 - 07/09/1999 16:24 Re: Random playlist [Re: tanstaafl.]
raphael
Loc: Austria
That's what the "suffle" function is all about. ;)
It either shuffles the playlist you're in, or in the "empeg-car" playlist.
Raphael Wegmann
raphael@psi.co.at
Raphael Wegmann
raphael@psi.co.at
#5947 - 08/09/1999 17:01 Re: Random playlist [Re: raphael]
So, you're saying the empeg already does what I want? I don't have mine yet (#8741) so I didn't know. Thanks, Raphael.
#5948 - 09/09/1999 07:12 Re: Random playlist [Re: raphael]
Dearing
Loc: Florida
How do you tell it which playlist to shuffle? I mean within a smaller playlist, aren't you still in the Empeg-Car Playlist, too?
Jason
_~= Dearing =~_
_~= Dearing =~_
#5949 - 13/09/1999 06:27 Re: Random playlist [Re: Dearing]
mac
Loc: Cambridge, UK
Shuffle mode is currently a bit strange (TM) :-)
Turn shuffle mode on or off _and then_ select the playlist you wish to play.
For playing purposes playlists contain everything directly or indirectly in the playlist (the "don't treat as part of parent" option which is coming soon notwithstanding). Therefore the empeg-car playlist contains everything since all other playlists are inside empeg-car.
BUG ALERT: Sometimes the shuffle mode indicator gets stuck in one state or the other. Note it is only the indicator which does this - the mode is being changed. A similar effect can be observed on the Information menu item. This affects all releases including beta6.
Mike Crowe
I may not be speaking on behalf of empeg above :-)
Mike Crowe
