#4553 - 08/09/1999 22:00 Programming the display
Verement
Loc: Boston, MA, US
I seem to remember reading this somewhere, but now I can't find it.
I have mmap'ed 2000 bytes from /dev/display, but my changes do not appear on the hardware... what is the magic ioctl or other incantation to blit the new image to the display?
Also, how do I control the front status LED?
#4554 - 09/09/1999 03:37 Re: Programming the display [Re: Verement]
ioctl(fd,_IO('d',0));
should do the screen format conversion to the hoopy hardware memory layout for the screen. Your mmap'ed image is pretty standard left to right, top to bottom, 4bpp layout.
Screen on & off (and amp on/off, they're controlled by the same high-side-driver):
ioctl(fd,_IOW('d',1, int), state);
where 'state' is 1 or 0.
There are other calls used to deal with the screen buffering (you can buffer screens to lock them with the audio DMA) but this sort of stuff really needs proper documentation (ie, we're a bit busy at the mo!)
#4555 - 10/09/1999 06:17 Re: Programming the display [Re: altman]
Verement
Loc: Boston, MA, US
Excellent.
I wrote some simple utilities to do screen captures and also to dump previous captures onto the display; I'm also writing a screen-dump-to-PNG converter so I can post images on the web.
Hugo, how do I toggle whether the LED is throbbing or steady?
#4556 - 10/09/1999 11:48 Re: Programming the display [Re: Verement]
This is a bit harder, involving me remembering how I programmed the PIC on the frontboard :)
When I work it out I'll tell you ;) I think it's to do with the state of LCD0 when the display is disabled: in one mode you have complete control from the main CPU, so you can make it do your own stuff under software control.
#4557 - 23/09/1999 00:32 Re: Programming the display [Re: altman]
raphael
Loc: Austria
What ioctl do I need to call, to turn the blinking standby LED off?
Raphael Wegmann
raphael@psi.co.at
Raphael Wegmann
raphael@psi.co.at
