#374355 - 04/05/2024 02:42
Doorbell Question
I have a doorbell with camera, and also two security cameras that are not part of the doorbell system.
I can watch someone ring the doorbell with either the doorbell camera or both security cameras. There is about a five second delay from the time the button is pushed until the chime inside the house rings. There is no audible sound before then. Except... the dogs go berserk, warning of barbarians at the gate the moment that button is pressed.
Question "a": How is this possible? Question "2": How can I fix this?
#374356 - 04/05/2024 11:53
Re: Doorbell Question
I would theorize the obvious: the circuitry in the "doorbell" may be emitting some dog-audio frequencies as it powers up and begins to transmit.
Which part of the "doorbell" is the question though.. more likely the inside part with the "bell" ?
#374357 - 04/05/2024 13:10
I should have mentioned, this is a hard-wired system. There is no transmitter. I don't know if a wireless system would work, it would have to transmit through two 12" thick masonry walls over a distance of 60 feet.
Nonetheless, I had reached the same conclusion about dog-audible sound, but since the doorbell button is is probably sending a single pulse to trigger a relay to power the door chimes the delay seems unusual.
Thinking more about it, since the wire is also transmitting video as well as a signal to ring the chimes, I suppose it is complicated enough that strange things can happen.
#374359 - 04/05/2024 19:02
Are you in the house when watching these cameras? Are you hearing the chime live or via the cameras? Occam's Razor here says that the chime is instantaneous in the house, and the cameras are showing you video that is synchronised with its own audio but is five seconds delayed from live.
#374360 - 04/05/2024 21:50
The doorbell doesn't have to emit any frequencies for the dogs to notice someone is at the door. The dogs merely hear the people walk up to the front door. They're better at that than we humans are, they just pick up on subtle things. If someone walked up to the door, close enough to ring the doorbell, but didn't actually push the button, then the dogs would still go nuts.
If the doorbell contains a camera, then it's some kind of smart doorbell system correct? There's probably some kind of delay in its system. Something in the electronics that perhaps deliberately delays the chime. Test it out yourself by ringing the doorbell by hand. Dunno how to fix it, but whatever brand it is, there's likely other people on the internet talking about the same issue so google it.
Another possibility:
Our physical doorbell has a two-stage chime, one chime rings when you press the button and another chime rings when you release the button. The solenoid that rings the bell emits a slight hum while the button is held down. Maybe the first of the two bells isn't working any more and only the second bell rings. The dogs hear the solenoid, but you don't hear the bell until the ringer pulls his finger off the button.
#374361 - 05/05/2024 14:26
[Re: peter]
Are you hearing the chime live or via the cameras? Yes. No. Yes: I hear the chime, standing a few feet away from it in the living room. No: I watch the button press both from from an independent camera (one of an eight camera security system that is not tied to the doorbell system in any way) and the doorbell camera, and can clearly watch while the button pusher stands around looking for the doorbell button, finally pushes it... and the dogs immediately go berserk to a dogs-only signal that nobody else can hear. Then, after about a five second delay, the chimes ring in the living room and the dogs go even more berserk. Clearly the button press creates some sound inaudible to humans before the chimes ring. People walking on the sidewalk, talking as they pass the door, do not trigger a response. Both the doorbell camera and the security cameras operate in real time, otherwise I couldn't talk to people on the doorbell system, and I can verify that there is no video or audio delay in the security camera by watching the gardener [should I be upscale and call him the Yard Supervision Manager? 😀] with his noisy tools. I don't know the details of how the doorbell system is powered, other than it is connected to house current. The wires are buried in the masonry walls and the button/camera is hardwired to the chimes/video-display unit. Probably at the chimes end the current is converted to low voltage (5v? 12v?) DC before being sent to the doorbell button end, but that's just guesswork. Maybe the chimes need more power and there is a delay charging up a capacitor to run them or something. Anyway, it's all a big mystery to me. tanstaafl.
#374362 - 05/05/2024 15:16
Are they physical chimes, or does it play an electronic sound?
If physical, maybe the solenoid is sticky and doesn't finish its chime cycle for a few seconds.
Or maybe the button itself is sticky, and so when you take your finger off the button, it's a few seconds before the solenoid releases and the second half of the chime sounds (and the first half of the chime is malfunctioning and silent, and the dogs are responding to the buzz of the solenoid, as I mentioned in my previous post). Our doorbell had the sticky button problem for a while until I fixed it, and the solenoid would stay stuck "on" for random amounts of time.
Oo, here's an idea. In my childhood home there were several chimes, the thing would play a full melody on a set of tuned physical tubes. Maybe the first few notes are malfunctioning on your melodic chimes, and only the final note rings out for you, and again, like in my earlier post, the dogs are responding to the buzz of the solenoids activating.
#374363 - 05/05/2024 15:38
Some googling tells me that there are kits which retrofit a smart camera doorbell onto old school physical chimes, and that these can sometimes exhibit the problem you describe. The issue seems to be in that retrofit circuit somewhere. Example: https://community.ring.com/t/ring-pro-video-doorbell-delay-in-ringing-mechanical-doorbell/4045Two sounds are emitted, according to that post: When the ring light around the button is off (dark) and the button is pressed, the Ring Pro device emits a sound immediately, BUT there is a delay of 3-5 seconds between pressing the button and the mechanical doorbell actually ringing.
#374364 - 05/05/2024 22:29
Are they physical chimes, or does it play an electronic sound? If physical, maybe the solenoid is sticky and doesn't finish its chime cycle for a few seconds. Or maybe the button itself is sticky ...the thing would play a full melody Chimes are electronic. The button is not sticky. The "full melody" is a two note "song". Press and release the button, the chimes play a "ding doo" sound (E followed by C) repeated once for a total of four notes, a one second pause between the pair, the first "ding doo" starting about five seconds after the button is released. If you press and hold the button, the chimes do not play, but [I think] the microphone is activated so the person pushing the bell can talk to the person inside. This is hard to test by myself, as the button is a good 60 or 70 feet away from the chime box in the house. I'll verify that when I have some help. tanstaafl.
#374365 - 06/05/2024 06:55
I guess the next steps depend a bit on how much you're prepared to annoy your visitors and/or your dogs in the name of Science. If you cut power to the whole system, do the dogs still go bananas? (Are they hearing the physical noise of the button-press?) If you disconnect the chimer's speaker leaving the button live (if that's possible), do they do it? (Does the chimer make some high-frequency coil whine or suchlike that they're hearing?) Assuming the button is "dumb" (momentary, normally-open), if you briefly short the wires at the chimer end (simulating a button-press) do the dogs react? (If you're that close to the chimer when it goes off, maybe *you* will hear the coil whine.)
#374366 - 06/05/2024 16:57
Wow so there is some kind of electronic delay in the system which delays the chime for 5 seconds. I wonder why.
#374367 - 06/05/2024 17:15
Maybe the chimes actually do ring immediately, but the electronic emitter doesn't play it loudly enough at the beginning. For example, maybe it repeats the melody three times instead of twice and you're not hearing the first one because it's not sending enough DC voltage to the emitter circuit at first. Maybe the voltage ramps up. And the dogs are hearing the quiet bit, but you're not.
Or maybe it's something to do with that talkback microphone you described. Maybe the button press engages the talkback mic, which (by design) delays/mutes the chimes, and the dogs are responding to the noise of the faint sound coming through the talkback speaker, or even just the faint click of the talkback system engaging at all.
#374368 - 06/05/2024 20:28
This is hard to test by myself, as the button is a good 60 or 70 feet away from the chime box in the house. This is tricky because the usual way someone would do this is to have the other person on the phone. But these days, cell phones introduce a significant round-trip delay. Like lag in Quake Arena, but much worse. With that run length, I wonder if there's some kind of a DC relay between the doorbell and the chimes, and the relay is being sticky (and could be the thing the dogs are hearing).
#374369 - 06/05/2024 21:31
I still think it's a "smart" device somewhere in the setup, that is taking a few seconds to boot before it rings the bell.
