#36762 - 19/08/2001 04:04 Setting up a dev environment on the Empeg
tigloo
Loc: Hamburg, Germany
Hello,
can anybody tell me how to setup a development environment on the Empeg itself? I have searched on the developer sites but only found information for cross compiling.
Frank van Gestel has a Debian archive on his page, but I am not really sure what to do with that one.
Till
#36763 - 19/08/2001 07:30 Re: Setting up a dev environment on the Empeg [Re: tigloo]
tigloo
Ok, after a bit of fiddling I put the Debian image on the Empeg and am now running it as chroot'ed environment. However, to be any useful, I need to do a dist-upgrade over the network and install packages the same way.
The only kernel I found to support PPP was a very old one... are there any newer kernels out there with PPP support compiled in?
Is it safe to install one of the old kernels that have PPP support?
Till
#36764 - 19/08/2001 07:49 Re: Setting up a dev environment on the Empeg [Re: tigloo]
Why do you need PPP? apt-get will work over normal Ethernet
#36765 - 20/08/2001 04:15 Re: Setting up a dev environment on the Empeg [Re: Roger]
tigloo
I thought so, too, but the developer sites gave me a different feeling. Anyway, I got it to work, with no DNS, however. I thought that PPP would automatically provide DNS and routing information.
Till
#36766 - 20/08/2001 05:46 Re: Setting up a dev environment on the Empeg [Re: tigloo]
Repeat after me: You don't need PPP.
You do need a working DHCP server -- in order to give you routing information. However, the player application doesn't save the DNS settings.
You probably also need the following:
/sbin/ifconfig
/bin/ping
/etc/services
/etc/protocols
/etc/nsswitch.conf
/lib/libnss_compat-2.1.2.so
/lib/libnss_db-2.1.2.so
/lib/libnss_files.so.2
/etc/host.conf
/etc/resolv.conf
/lib/libnss_dns*
/lib/libdb*
/lib/libresolv*
You can find them here.
#36767 - 20/08/2001 05:53 Re: Setting up a dev environment on the Empeg [Re: Roger]
tigloo
Repeat after me: I got it working already!
Only the first synch to match Debian Potato wasn't able to use DNS, after that everything was pretty easy.
Thanks though. :)
Till
#36768 - 20/08/2001 07:18 Re: Setting up a dev environment on the Empeg [Re: tigloo]
Cool . Hopefully someone else will find the other stuff useful, anyway.
#36769 - 21/08/2001 04:25 Re: Setting up a dev environment on the Empeg [Re: Roger]
smu
Loc: Germany (Ruhrgebiet)
I do.
proud MkII owner (12GB blue/green/smoked, was #080000113 is #090001010)
#36770 - 28/08/2001 13:07 Re: Setting up a dev environment on the Empeg [Re: Roger]
schofiel
You do off course, need ethernet. That rules out Mk1 owners then
You do need PPP over serial.
And just why are you so grumpy, Roger?
