#359969 - 16/10/2013 10:07 Excel Question
I need to create a unique ID ("SupplierCode.xxxxxx") where SupplierCode is one of the columns, the sequential number is generated on a per supplier basis.
Any ideas? (Hope the above makes sense)
#359970 - 16/10/2013 14:06 Re: Excel Question [Re: tahir]
How about:
="SupplierCode"&ROW()
If they are all in the same column and you never change rows.
#359971 - 16/10/2013 14:27 Re: Excel Question [Re: larry818]
I think there is a method for pre-populating a selected column with sequential 'serial' numbers. Forget what that is called, at the moment.
Select the column area that needs the numbers, activate the command and you should have your number series. This assumes that you know or can predict the total number of 'serial numbers' you need.
#359972 - 16/10/2013 14:59 Re: Excel Question [Re: tahir]
=A2&"."&(COUNTIF(INDIRECT("A$1:A"&ROW()-1), A2)+1)
The SupplierCode needs to be in column A, this would go in B2. Which would result in this:
[img]https://photos-3.dropbox.com/t/0/AAAlUyo...-VVelKcthEp3clQ[/img]
What the formula does is look back up the A column and counts all the supplier codes that match the supplier code on the current row. Then it adds one to the count and uses that for the sequential number. So each supplier gets their own incrementing set of numbers.
I am probably being over complicated with the INDIRECT, this works just as well:
=A2&"."&(COUNTIF(A$1:A1, A2)+1)
Edited by andy (16/10/2013 15:09)
#359973 - 16/10/2013 15:01 Re: Excel Question [Re: andy]
Why have dropbox made it such a pain to get a working link to an image nowadays *sigh*
(I know why, but it is still a pain)
#359974 - 16/10/2013 15:58 Re: Excel Question [Re: andy]
imgur is painless to use for images that you don't care who sees
#359975 - 16/10/2013 16:00 Re: Excel Question [Re: andy]
Thanks guys but I managed to sort it, with the following:
=(COUNTIF($D$1:D2,D2))
AND
=D2 & "." & TEXT(AD2,"000000")
