More info I just discovered:
On the server (currently running 7.5.0 due to trying a downgrade from 7.5.1, to no avail) web interface, open on the server machine itself, I see that the player I'm using as alarm clock is being showed as if it is in fact playing the tune I selected.
In reality, the player is showing the error message on screen, rebooting, acquiring an IP again, and then doing nothing while the web interface on the server machine still shows it playing the tune!
This happens on both players (Boom and classic), and it also happens when I try to play some of the squeezebox sounds (which are still on the server side).
So, I would tend to believe, although I am not sure, that the server side is ok, while the client/player has something wrong. I can't think of what I changed, though.
For the records, 7.5.0 and 7.5.1 have been working great for a long time before this issue showed.
I am thinking that the only change I made to the players is to use them in synch mode a few times, only to deactivate synch after doing so, each time. Currently they are not in sych mode.
This is very annoying. Basically I can't use the boom as an alarm clock, which is one of the main reasons I bought it.
