It did put all the pictures in there but there is a seam showing and I don't see any options in that program at all.
You are right, there is a seam showing between the first and second (left-to-right) pictures. 20 seconds with the clone tool in Paint.net made it go away. You have a lot of overlap with those two shots, so the seam is surprising. I'm guessing that there just isn't enough detail (as gbeer suggested) to make a foolproof join.
What I like about the Microsoft ICE program is that there
aren't many options in the program. It just works. I have never had it fail if I had at least a 15% overlap on the pictures, and it does things like automatically adjust exposure between the individual pictures as it stitches them. In the sample I posted, I set the camera to manual focus and exposure (all shots were f-8 at 1/500 second, 90 mm focal length at 35mm equiv.) and the 270 degree sweep included everything from shooting directly towards the sun to shooting directly away from it. Using the camera's automatic exposure would have varied the exposure by three f-stops from one end to the other. At this point I'm not sure whether I would have been better to let the camera set the exposure, or let the ICE program make the adjustments. In any case, the results speak for themselves.
I found the Autostitch options to be confusing and non-intuitive, and am happy to concede that the Microsoft program's default parameters work better than I could manage to do myself. I figure as long as the pictures stitch together seamlessly and look just like any one of the original pictures, well... "Options? We don' need no steenkin' options!"
Just for the fun of it, I am attaching two tiny excerpts (.04% of the full stitched image), one of them at the low resolution of the panorama attached earlier in this thread, and the other at the high resolution of the original panorama. Someday I may go completely crazy and set the focal length to 360mm and re-shoot the panorama at ultra-high resolution, which will require, ummm, let's see. 90mm focal length required 36 exposures, 180mm would require 4 times as much, and 360mm would require 4x
that, so it would be 576 exposures, about 2 GB factoring in the overlap. According to Microsoft, there is no practical limit to the number of exposures ICE will stitch, the problem being that there are not many (if any?) programs that can open a 2GB graphics file.
