#332592 - 29/04/2010 21:45
Scratches on glass
I have some very nice custom cabinetry with glass fronted doors. One of the doors has a scratch in the glass, not deep (but deep enough to catch a fingernail on) and I'm wondering what if any remedy might be available?
#332594 - 29/04/2010 23:13
Re: Scratches on glass
You could take a black sharpie and paint in the scratch, that might make it less noticeable.
Take the door to a glass shop. They should have no problem replacing the glass with new. Most likely cheaper than you might think.
#332595 - 29/04/2010 23:17
A new piece of glass. Unless there's etching or complicated beveling, it's almost certainly not worth your while to try to "remove" the scratch. Glass is cheap and almost always very easy to replace. If you want to repair it, there are three theoretical options: - Fill the scratch with a material that has the same refractive index as the glass. These tend to chip out, and different glasses have different refractive properties.
- Buff the scratch out. Unless you're willing to live with very noticeably scratched glass, you're going to spend hours polishing.
- Melt the glass. Take a blowtorch to it and you might be able to knock the sharp edges off of the scratch. I cannot imagine that this would work well at all in practice. You're far too likely to melt soot into the glass, have a nasty sag, or torch a hole through it, or all of the above, assuming you can get it to melt at all. Sounds like a fun thing to try after you've already replaced the glass, though.
#332596 - 29/04/2010 23:25
The only problem with replacing the glass is that you might wind up replacing the glass in all the cabinets.
The new might just not match the existing in some way or another. The color of the glass might be off, just enough to notice. Same for the thickness. Then there is the fact that the new glass is well... New! No dust or smut in the corners.
#332597 - 29/04/2010 23:59
[Re: gbeer]
How about an auto glass shop and have them do the chip repair were they fill it with epoxy.
#332605 - 30/04/2010 10:35
Melt the glass. Take a blowtorch to it and you might be able to knock the sharp edges off of the scratch. I cannot imagine that this would work well at all in practice. You're far too likely to melt soot into the glass, have a nasty sag, or torch a hole through it, or all of the above, assuming you can get it to melt at all. Sounds like a fun thing to try after you've already replaced the glass, though. I cannot get images of Pat and Mat from A Je To cartoons out of my head. Sorry!
Edited by bonzi (30/04/2010 10:37)
Dragi "Bonzi" Raos
Q#5196
MkII #080000376, 18GB green
MkIIa #040103247, 60GB blue
#332609 - 30/04/2010 11:18
[Re: bonzi]
I hadn't heard of them until now. Thanks, bonzi! (And YouTube!)
#332616 - 30/04/2010 16:06
Unless there's etching or complicated beveling, it's almost certainly not worth your while to try to "remove" the scratch. Glass is cheap and almost always very easy to replace. There is complicated beveling, and it would not be easy to replace. The cabinet door would have to be replaced as the glass is very integrally sandwiched into a very seriously glued-together wooden frame. I think I can live with the scratch, and was wondering if something like Carnauba car wax might make it less noticeable. As you can see from the picture, it is not a traumatizing defect. The other picture shows the whole cabinet. To get an idea of the scale, that refrigerator is 68" tall. And Bitt, you will be pleased to see that I did indeed "...replace that chandelier in the kitchen..." ![smile smile](/images/graemlins/default_dark/smile.gif) tanstaafl.
![Scratch.jpg Scratch.jpg](/ubbthreads.php/ubb/download/Number/6019/filename/Scratch.jpg)
#332618 - 30/04/2010 16:47
Yeah, even that relatively simple beveling is going to quadruple the price of the glass.
#332637 - 30/04/2010 22:56
Again, go talk to a glass shop.
#332638 - 30/04/2010 23:38
[Re: gbeer]
There is always the get used to it, it adds character option.
#332641 - 01/05/2010 03:40
[Re: msaeger]
Yeah! In fact, add more scratches!
#332652 - 01/05/2010 13:52
Yeah! In fact, add more scratches! OK, Bitt, and when I do that are you gong to pitch in and help pay for the divorce attorney? ![smile smile](/images/graemlins/default_dark/smile.gif) tanstaafl.
#332668 - 01/05/2010 20:31
Bumper Sticker!
#332675 - 02/05/2010 06:24
There is complicated beveling, and it would not be easy to replace. The cabinet door would have to be replaced as the glass is very integrally sandwiched into a very seriously glued-together wooden frame. Forget the cabinet, that ceiling is great, is the whole house vaulted brick? What does the roof look like?
#332678 - 02/05/2010 14:01
[Re: tahir]
Forget the cabinet, that ceiling is great, is the whole house vaulted brick? What does the roof look like? Both the kitchen and the bedroom have the vaulted brick ceiling -- called a boveda in espaņol. The high point of the ceiling is 14 feet above the floor. You can get a feel for the layout by looking at the attached pictures. tanstaafl.
#332696 - 03/05/2010 23:10
Neat and clean, dose the the roof drain into a cistern.
#332697 - 03/05/2010 23:42
[Re: gbeer]
Neat and clean, dose the the roof drain into a cistern. No. We are on municipal water here. The municipal water is said to be non-potable, OK for bathing and tooth brushing, not for consumption. That said, I am unaware of anyone actually becoming ill from drinking it. tanstaafl.
