#332275 - 21/04/2010 17:36 kernel panic unable to mount root fs
cdodds
Loc: Warren, AR
Need help, haven't used player in about 5 years, thought it was the hard drive at first, but took it out works fine. My player is stuck at the first boot logo RIO, hooked up a serial cable and the got connected.
Error Message:kernel panic unable to mount root fs
Help!!!!!! Let's keep it alive
#332276 - 21/04/2010 17:38 Re: kernel panic unable to mount root fs [Re: cdodds]
Let's start with a full serial boot log and we'll go from there.
#332282 - 21/04/2010 18:57 Re: kernel panic unable to mount root fs [Re: tfabris]
cdodds
Loc: Warren, AR
e000 v1.03
Copying kernel...
Calling linux kernel...
Uncompressing Linux.................................... done, booting the kernel
Linux version 2.2.14-rmk5-np17-empeg41 (mac@aphex.internal.empeg.com) (gcc versi
on 2.95.2 19991024 (release)) #132 Wed Jan 10 13:49:24 GMT 2001
empeg-car player (hardware revision 9, serial number 30103063)
Command line: mem=16m temp=40
Memory: 15048k/16M available (972k code, 20k reserved, 336k data, 8k init)
Linux NET4.0 for Linux 2.2
IP Protocols: ICMP, UDP, TCP
Starting kswapd v 1.5
Signature is 206f6972 'rio '
Logo type is 1
empeg display initialised.
empeg dspaudio driver initialized
empeg audio-in initialised, CS4231A revision 08
empeg infra-red support initialised.
empeg usb initialised, PDIUSBD12 id 0000
empeg state support initialised 0089/88c1 (save to d0005000).
empeg single channel IDE
Probing primary interface...
smc chip id/revision 0x0001
smc_init couldn't find card
empeg-pump v0.03 (19980601)
Press Ctrl-A to enter pump...VFS: Cannot open root device 03:05
Kernel panic: VFS: Unable to mount root fs o
e000 v1.03
Copying kernel...
Command line: mem=16m temp=25
Logo type is 1
empeg audio-in initialised, CS4231A revision 19
empeg state support initialised 0089/88c1 (save to d0005080).
Kernel panic: VFS: Unable to mount root fs on 03:05
e000 v1.03
Copying kernel...
Logo type is 1
empeg state support initialised 0089/88c1 (save to d0005100).
e000 v1.03
Copying kernel...
Command line: mem=16m temp=27
Logo type is 1
empeg state support initialised 0089/88c1 (save to d0005180).
#332286 - 21/04/2010 19:51 Re: kernel panic unable to mount root fs [Re: cdodds]
Hook up the hard drive again, then post the output with it connected.
#332287 - 21/04/2010 19:51 Re: kernel panic unable to mount root fs [Re: mlord]
Oh, wait a sec.. install a Hijack kernel first.
#332290 - 21/04/2010 20:05 Re: kernel panic unable to mount root fs [Re: mlord]
cdodds
Loc: Warren, AR
v508.hijack.mk2.zImage
is the one?
#332301 - 21/04/2010 20:57 Re: kernel panic unable to mount root fs [Re: cdodds]
cdodds
Loc: Warren, AR
I did everything and got an error meessage on my player no hard disk found contact support
What's next?
#332302 - 21/04/2010 21:06 Re: kernel panic unable to mount root fs [Re: cdodds]
Post the serial log again, from booting with the Hijack kernel.
#332307 - 21/04/2010 21:40 Re: kernel panic unable to mount root fs [Re: mlord]
cdodds
Loc: Warren, AR
Whether you believe it the ide cable was backwards from when i tested the hard. Thanks a thousand
#332308 - 21/04/2010 21:41 Re: kernel panic unable to mount root fs [Re: cdodds]
cdodds
Loc: Warren, AR
need a FM tuner now!!!!!!!!!!!!!!!!!!!!!!!
