#313537 - 03/09/2008 21:08 The usual: no codec found when trying to play a video
Except this is WinXP, which I'd been led to believe didn't have the "missing codec" problem that people (incorrectly) associate with Linux systems.
So.. how do I get it to play an mpeg4 video ??
#313538 - 03/09/2008 21:09 Re: The usual: no codec found when trying to play a video [Re: mlord]
Install Xvid
#313539 - 03/09/2008 21:14 Re: The usual: no codec found when trying to play a video [Re: tman]
Install Xvid
No change. I think perhaps something better than wimpy11 is needed. What do people use to view their media on this wretched platform?
#313540 - 03/09/2008 21:16 Re: The usual: no codec found when trying to play a video [Re: mlord]
It an AVI? If so then WMP should be enough. Any idea what the FourCC is for it?
#313541 - 03/09/2008 21:17 Re: The usual: no codec found when trying to play a video [Re: tman]
If all else fails then just install VLC. That usually plays pretty much everything and doesn't need codecs installed since it has its own.
#313542 - 03/09/2008 21:20 Re: The usual: no codec found when trying to play a video [Re: tman]
Ahh.. good suggestion. I think that's what I'll try next. Hopefully my earlier attempts at adding codecs and the like didn't install too much spyware.
(it's in .avi format, output from mencoder).
#313543 - 03/09/2008 21:20 Re: The usual: no codec found when trying to play a video [Re: mlord]
I wanted to try RealPlayer as an alternative, but the installer dies with a scripting error. frown
#313544 - 03/09/2008 21:22 Re: The usual: no codec found when trying to play a video [Re: tman]
It's in a .avi container, and file reports:
2041_20080824180000.avi: RIFF (little-endian) data, AVI, 720 x 400, ~30 fps, video: FFMpeg MPEG-4, audio: Dolby AC3 (stereo, 48000 Hz)
#313546 - 03/09/2008 21:28 Re: The usual: no codec found when trying to play a video [Re: mlord]
Mmm.. no joy. Black video from VLC.
Here's a simple cut of the first 5MB of the file: can you play it there? (works fine on Linux)
http://rtr.ca/sample.avi
#313547 - 03/09/2008 21:34 Re: The usual: no codec found when trying to play a video [Re: mlord]
Heh.. vlc on Linux plays the file just fine, of course.
#313548 - 03/09/2008 21:38 Re: The usual: no codec found when trying to play a video [Re: mlord]
Easiest thing to do is install a codec pack. I've had good luck in the past with the K-Lite Codec Pack.
And, for what it's worth, GSpot is a good tool for divining information about video files.
Edited by wfaulk (03/09/2008 21:40)
Edit Reason: GSpot
#313549 - 03/09/2008 21:39 Re: The usual: no codec found when trying to play a video [Re: mlord]
Happy Birthday Waterman981
Loc: Salt Lake City, UT
I always use ffdshow as the only codec I install anymore. It will decode and encode everything I need.
If you still need a player I really like Media Player Classic.
Edit: and your file played back perfectly for me.
Edited by Waterman981 (03/09/2008 21:48)
Edit Reason: feedback
-Michael
#040103696 on a shelf
#313550 - 03/09/2008 21:40 Re: The usual: no codec found when trying to play a video [Re: mlord]
Okay, I've gotten vlc to work, by cranking down the "hardware acceleration" setting for the Radeon driver to midway instead of full acceleration.
Ugh. See, the trick is, I'm mailing these videos cross-country to the most technically illiterate family imaginable.
#313551 - 03/09/2008 21:45 Re: The usual: no codec found when trying to play a video [Re: mlord]
Your best bet would be to transcode it into something else. Sending video is a massive PITA. Got to make sure the audio and video codecs match on both ends etc...
The specific FourCC that it wants is for ffdshow. I've tried changing the FourCC to XVID or DIVX but it just doesn't like it but that might be because the file has been truncated.
#313552 - 03/09/2008 21:46 Re: The usual: no codec found when trying to play a video [Re: mlord]
Transcode to an oldish WMV or make a DVD video maybe?
#313553 - 03/09/2008 21:46 Re: The usual: no codec found when trying to play a video [Re: mlord]
Easiest way to be sure would be to reencode it into a format for which all Windows PCs will have support. I'm sure there are some reasonable AVI codecs, but WMV is basically guaranteed.
Also, do they have a DVD player? Burn a video DVD and send them that.
Edited by wfaulk (03/09/2008 21:47)
#313555 - 03/09/2008 22:13 Re: The usual: no codec found when trying to play a video [Re: mlord]
You could also try encoding to flash video. Then you wouldn't have to send video anywhere, they could just view it online. You can get some pretty good quality from Youtube, and that other one I'm forgetting at the moment...
As for codec hell in Windows, like others have said, just use VLC. I'm sorry, Bitt, but codec packs are awful. They're just a mess, and there's really no way to uninstall what they put on. I definitely say install VLC and never worry about codecs ever again.
And I second the suggestion for Media Player Classic. VLC is lighter than most playback software, but MPC is the lightest I've seen that can play as many types of files. That, and MPlayer, which has some nice GUIs for Windows now.
All that said, I'm sorry Mark but are you sure that file is encoded properly? VLC definitely gave me an error when opening it, but it still played afterwards. That says to me: "encoding issue."
#313556 - 03/09/2008 22:17 Re: The usual: no codec found when trying to play a video [Re: Dignan]
It did play fine for me with ffdshow... in both MPC and WMP.
-Michael
#313558 - 03/09/2008 23:23 Re: The usual: no codec found when trying to play a video [Re: Waterman981]
Plays fine on win2K and VLC with the Nemo codec pack. MP won't play it, claiming it's opened by another app. Stupid.
#313559 - 03/09/2008 23:33 Re: The usual: no codec found when trying to play a video [Re: Dignan]
Yeah, the real file is fine -- the sample.avi I provided is just a raw chop of the first 5MB of the real file, missing the index from the tail end etc.. which is why vlc complains (but plays it fine regardless).
#313560 - 03/09/2008 23:35 Re: The usual: no codec found when trying to play a video [Re: Waterman981]
Ah.. so ffdshow is just a (good) codec package, for general use by wimp11 and others ?
#313561 - 03/09/2008 23:48 Re: The usual: no codec found when trying to play a video [Re: mlord]
Gspot says
FILE_NAME                      sample.avi
FILE_NAME_WITH_PATH            C:\Documents and Settings\Glenn\Desktop\sample.avi
FILE_SIZE                      5,242,880
CONT_AUDIO_STREAM_COUNT        1
CONT_BASETYPE                  AVI(.AVI)
CONT_BYTES_MISSING             1068497458
CONT_INTERLEAVE_ALIGN          Split
CONT_INTERLEAVE_PRELOAD        512
CONT_INTERLEAVE_TIME           500
CONT_SUBTYPE                   OpenDML (AVI v2.0),
CONT_TOTAL_BITRATE             0
VIDEO_ASPECT_CONVERT_AVI1
VIDEO_ASPECT_CONVERT_AVI2
VIDEO_ASPECT_CONVERT_CVD1
VIDEO_ASPECT_CONVERT_CVD2
VIDEO_ASPECT_CONVERT_DVD1
VIDEO_ASPECT_CONVERT_DVD2
VIDEO_ASPECT_CONVERT_SVCD1
VIDEO_ASPECT_CONVERT_SVCD2
VIDEO_ASPECT_CONVERT_VCD1
VIDEO_ASPECT_CONVERT_VCD2
VIDEO_ASPECT_SOURCE_MATCH
VIDEO_ASPECT_TYPE_NTSC
VIDEO_ASPECT_TYPE_PAL
VIDEO_BITRATE                  844
VIDEO_CODEC_NAME               FFmpeg/ffdshow ISO MPEG-4
VIDEO_CODEC_STATUS             Codec(s) are NOT Installed
VIDEO_CODEC_TYPE               FMP4
VIDEO_DAR                      1.800
VIDEO_DURATION                 0:33.868
VIDEO_FIELDS_PER_SEC
VIDEO_FRAME_COUNT              1015
VIDEO_FRAMES_PER_SEC           29.970
VIDEO_H264
VIDEO_MPEG2
VIDEO_MPEG2_3X2
VIDEO_MPEG2_BFF
VIDEO_MPEG2_I_L
VIDEO_MPEG2_PPF
VIDEO_MPEG2_PROG
VIDEO_MPEG2_TFF
VIDEO_MPEG4                    MPEG-4
VIDEO_MPEG4_BVOP
VIDEO_MPEG4_GMC
VIDEO_MPEG4_NVOP
VIDEO_MPEG4_QPEL
VIDEO_PAR                      1.000
VIDEO_PICS_PER_SEC             29.970
VIDEO_QF                       0.098
VIDEO_SAR                      1.800
VIDEO_SIZE_X                   720
VIDEO_SIZE_Y                   400
AUDIO_BITRATE                  384
AUDIO_BITRATE_TYPE             CBR
AUDIO_CHANNEL_COUNT            6
AUDIO_CODEC                    0x2000 (Dolby AC3) AC3
AUDIO_CODEC_STATUS             Codec(s) are Installed
AUDIO_MPEG_STREAM_ID
AUDIO_MPEG_SUBSTREAM_ID
AUDIO_SAMPLE_RATE              48000
#313567 - 04/09/2008 00:33 Re: The usual: no codec found when trying to play a video [Re: mlord]
Attack
Loc: Florida
I use DefilerPak and Zoomplayer and have it download the codecs. You can also try CoreAVC. I've heard it is very good.
Edit:
Your sample file plays perfectly for me.
Edited by Attack (04/09/2008 00:37)
Chad
#313570 - 04/09/2008 00:46 Re: The usual: no codec found when trying to play a video [Re: Dignan]
Many are awful. I linked to one I've had success with. All it does is install some codecs and a few pieces of software, like GSpot and MPC. Installing individual codecs always left me in a bigger mess if I had to install more than one or two.
MPC uses the Windows codec system. If he can't play it with WMP, he can't play it with MPC. Period. It's merely a different UI for the exact same playback software built into Windows.
#313572 - 04/09/2008 01:18 Re: The usual: no codec found when trying to play a video [Re: mlord]
I've since replaced the sample.avi file with a full/complete sample (same codecs), and vlc no longer complains about it on startup. Otherwise no difference (still need to crank down the h/w accel on my P4 Radeon box).
Recoding as WMV (both version 1 and version 2) didn't work, neither did ordinary mpeg-2. I like the format I've already coded to, as it also keeps the audio perfectly in sync.. something that other encoding options seem to bugger up.
I've sent a link for the sample.avi to the intended recipient, along with a link for the vlc installer, and asked her to try those and report back.
If all goes well, I'll burn the videos to DVD-ROM and mail them across the country.
Thanks folks!
#313575 - 04/09/2008 03:37 Re: The usual: no codec found when trying to play a video [Re: mlord]
Sadly video playback is pretty much a mess on any OS. Too many formats, too many companies with their own attempts to control the market, and no clear leader. Video never has had quite the killer format like audio did with MP3.
#313576 - 04/09/2008 06:00 Re: The usual: no codec found when trying to play a video [Re: mlord]
Video driver or codec bug. I had a similar problem with WMP on a Radeon card -- things that were too bright came out black. VLC obviously does something different (probably not exercising the acceleration quite so much), because that worked OK.
That card's since gone bang, so I can't check your file for you...
#313624 - 04/09/2008 19:09 Will it never end? WinXP UDF support? [Re: mlord]
So, I'm burning these 3-GByte files to DVD-R now, to mail out west. Burned first disc, and popped it into the WinXP box here just to ensure things are alright, and...
It comes up with an empty root directory on the DVD.
"Properties" shows that XP knows it is a "UDF" filesystem, but it refuses to show the contents.
Again, this works fine on Linux, even on the exact same machine.
http://support.microsoft.com/kb/321640
Q: Does Vista also suffer this M-bare-ass-ment?
Q: Is there a spyware-free UDF driver available for XP?
Thanks guys.
#313626 - 04/09/2008 19:24 Re: Will it never end? WinXP UDF support? [Re: mlord]
Have you closed the session?
Use a different UDF variant? XP can do UDF but not whatever one you're using it seems.
#313628 - 04/09/2008 19:46 Re: Will it never end? WinXP UDF support? [Re: mlord]
Mmm.. judging from Google results, I'd say that both XP and Vista lack full UDF support. Bummer.
I think I'll just mail a USB hard drive to her, instead of trying to fiddle further with this lack of basic functionality.
