#310857 - 02/06/2008 21:14 setting ip...
Boelle
Loc: Denmark, Odense
my config.ini is like this:
[Network]
Gateway=192.168.1.1
Netmask=255.255.255.0
IPAddress=192.168.1.11
but it is still geting the ip by dhcp... have i mis-configured?
#310858 - 02/06/2008 21:20 Re: setting ip... [Re: Boelle]
Boelle
adding: DHCP=0 does the trick
#310859 - 02/06/2008 21:34 Re: setting ip... [Re: Boelle]
You're supposed to plug it in via serial and then configure the network settings using Emplode.
#310860 - 02/06/2008 21:38 Re: setting ip... [Re: tman]
Boelle
yeah, but on my old laptop emplode can't find it, but putty and hyberterminal works...
#310861 - 02/06/2008 22:04 Re: setting ip... [Re: Boelle]
You checked the baud rate and whether your cable has all the handshaking lines wired up?
#310871 - 03/06/2008 08:28 Re: setting ip... [Re: tman]
Boelle
yes, org. cable that came with the player and 115200,8N1,Off
115200,8N1,Off is what makes it run under putty and hyberterminal but NOT in emplode
#310872 - 03/06/2008 08:28 Re: setting ip... [Re: Boelle]
Boelle
anyway it is working now in emplode over network
