#308615 - 27/03/2008 11:50 Cannot Exit Player Mode in Hyperterminal
Gleep
Loc: Iowa
Here is my boot capture. I've tried Cntrl+C, Q, and Cntrl-Break
Empeg screen says Building music databases...
e000 v1.04
Copying kernel...
Calling linux kernel...
Linux version 2.2.17-rmk5-np17-empeg52-hijack-v445 (hijack@rtr.ca) (gcc version 2.95.3 20010315 (release)) #2 Sat Mar 11 11:11:45 EST 2006
Checking for extra DRAM:
c1000000: wrote ffffffff, read e91ba9f0
empeg-car player (hardware revision 9, serial number 40104282) 16MB DRAM
Command line: mem=16m
Memory: 15008k/16M available (988k code, 20k reserved, 364k data, 4k init)
Linux NET4.0 for Linux 2.2
IP Protocols: ICMP, UDP, TCP
Starting kswapd v 1.5
Signature is 67706d65 'empg'
Found custom animation at offset 0x9dfb8
Tuner: loopback=0, ID=-1
Scheduling custom logo.
empeg display initialised.
empeg dsp audio initialised
empeg dsp mixer initialised
empeg dsp initialised
empeg state support initialised 0089/88c1 (save to d0004700).
empeg RDS driver initialised
empeg single channel IDE
Probing primary interface...
hdb: IC25N080ATMR04-0, ATA DISK drive
hda: HTS421212H9AT00, ATA DISK drive
hda: HTS421212H9AT00, 114473MB w/7528kB Cache, CHS=14593/255/63
hdb: IC25N080ATMR04-0, 76319MB w/7884kB Cache, CHS=9729/255/63
smc chip id/revision 0x3349
SMC9194: SMC91C94(r:9) at 0x4008000 IRQ:7 INTF:TP MEM:6144b MAC 00:02:d7:28:10:ba
Partition check:
RAMDISK: Loading 320 blocks [1 disk] into ram disk... |/-\|/-\|/-\|/-\|/-\done.
empeg-pump v0.03 (19980601)
Press Ctrl-A to enter pump...
Mounting proc
khttpd: listening on port 80
kftpd: listening on port 21
Thanks in advance!
#308622 - 27/03/2008 13:14 Re: Cannot Exit Player Mode in Hyperterminal [Re: Gleep]
Sometimes this is because you've not got your serial connection configured correctly. In particular, check the flow control settings. It's all in the FAQ.
Failing that, ditch Hyperterminal: use TeraTerm (on Windows) or minicom (on Linux, etc.) instead.
#308623 - 27/03/2008 14:10 Re: Cannot Exit Player Mode in Hyperterminal [Re: Roger]
Gleep
Loc: Iowa
I had a working Hyperterminal config on my pc that crashed the week before so I am having to start over on all my Empeg stuff for the PC. I used the settings from the FAQ, but I will try TeraTerm when I get home tonight. Thanks!
#308625 - 27/03/2008 14:32 Re: Cannot Exit Player Mode in Hyperterminal [Re: Gleep]
You might also want to try PuTTY. Newer versions have supposedly more stable serial support, and the user interface isn't nearly as bad as TeraTerm's. And it has other uses, too.
#308652 - 28/03/2008 02:19 Re: Cannot Exit Player Mode in Hyperterminal [Re: wfaulk]
Gleep
Loc: Iowa
Re installed the developer 2.0 image and was able to get a bash prompt. Tried
ro
umount /dev/hda4 (Please note! The command is umount, not unmount.)
umount /dev/hdc4 (If you have only one hard disk, you may omit the lines that include /dev/hdc4.)
swapon /swapfile
fsck -fay /
fsck -fay /dev/hda4
fsck -fay /dev/hdc4
swapoff /swapfile
sync
and
ro
rom
fsck.ext2 -fay -b 32768 /dev/hda4
and
rwm (There will be a long pause)
rm /drive0/var/database
rm /drive0/var/database3
rm /drive0/var/tags
rm /drive0/var/playlists
rm /drive1/var/database
rm /drive1/var/database3
rm /drive1/var/tags
rm /drive1/var/playlists
(Note that some or all of those RM commands may not work, that's OK)
exit
(The player application will run and rebuild the databases; watch the screen and wait until it is done, then q out of it again...)
q
(This should exit the player application back to the shell prompt.)
rom
exit
But it still boots up to
And sits there.
#308653 - 28/03/2008 02:39 Re: Cannot Exit Player Mode in Hyperterminal [Re: Gleep]
Running that fsck.ext2 without rebooting immediately afterwards might have caused some problems. The fsck on /, too.
#308660 - 28/03/2008 11:06 Re: Cannot Exit Player Mode in Hyperterminal [Re: wfaulk]
Gleep
Loc: Iowa
I did the reboot after each of the 3 sections I listed in my earlier post as directed by the FAQ.
I do think it is a corruption problem as I wanted to see if my mp3 files were there, so I went to the fids directory and did ls -la and it hangs. I can hit Cntrl-C and cancel. If I do just ls I get a listing of all the files.
The fsck's I did as instructed in the FAQ did not report any errors. My troubles started when I was loading a new CD using jemplode and it froze in the middle.
#308755 - 31/03/2008 20:53 Re: Cannot Exit Player Mode in Hyperterminal [Re: Gleep]
Gleep
Loc: Iowa
Redid the
ro
swapon /swapfile
fsck -fay /
fsck -fay /dev/hda4
fsck -fay /dev/hdc4
swapoff /swapfile
sync
reboot
and all is now well!
