#304175 - 20/11/2007 20:00 Forcing a shutdown in OSX
So I've written a great little script that makes a set of symlinks that point to specific folders depending upon the day. This runs off a cron tab on an OSX server at 10 past midnight every night. The folder containing these symlinks is shared over NFS to a bunch of other macs. The problem I have is that although the symlinks update, you can see that in a terminal window, the little alias folders in Finder don't. It seems only a disconnect and reconnect to the share or a restart updates the alias folders.
So my question, is there any way to force a shutdown of a machine regards of anything running on it? The lusers are too stupid to remember to shut them down each night.
#304176 - 20/11/2007 20:03 Re: Forcing a shutdown in OSX [Re: andym]
Make this Applescript script:
ignoring application responses
tell application "Finder"
shutdown
end tell
end ignoring
And then run it from cron using the "open" command.
#304177 - 20/11/2007 20:19 Re: Forcing a shutdown in OSX [Re: wfaulk]
shutdown needed to be changed to shut down. But the apps still sit there asking for confirmation to quit.
#304178 - 20/11/2007 20:43 Re: Forcing a shutdown in OSX [Re: andym]
Hmm. That's what the "ignoring" is supposed to avoid, obviously.
I assume you've tried the shutdown or reboot command.
How about "System Events" instead of "Finder"?
Edited by wfaulk (20/11/2007 20:46)
#304179 - 21/11/2007 04:05 Re: Forcing a shutdown in OSX [Re: andym]
Terminal command "shutdown -h now" to shutdown or "shutdown -r now" for a restart. No GUI confirmations so unsaved work will be lost. But to OS X, it is a proper shutdown, just like any other Unix OS.
#304180 - 21/11/2007 19:26 Re: Forcing a shutdown in OSX [Re: drakino]
That did it, stuck it in root's crontab and prefixed it with /sbin/
Now all the machines power off at 5 to midnight every night
