#296631 - 06/04/2007 20:08 Fan Control Error
Fairly often when I boot up my empeg, I get a "Fan Control Error" warning. Seems to happen more frequently at first startup of the day.
What is this, is it something I should worry about?
The MK II-A player is (obviously) equipped with a fan (installed by Stu at Eutronics), running 2.0 Final with HiJack v.413.
#296632 - 06/04/2007 21:53 Re: Fan Control Error [Re: tanstaafl.]
maczrool
Loc: Louisiana, USA
You've probably got a loose wire somewhere between the fan controller and mainboard. Check and make sure all the connections are still solid.
Stu
Edited by maczrool (06/04/2007 22:09)
