#291371 - 11/12/2006 01:43 Sometimes it boots, sometimes it doesn't
robricc
Here's a log from when it doesn't boot. What looks likely here? Hopefully it's something simple (drive cable). The IDE header seems to be in place.
e000 v1.04
Copying kernel...
Calling linux kernel...
Linux version 2.2.17-rmk5-np17-empeg52-hijack-v464 (hijack@rtr.ca) (gcc version 2.95.3 20010315 (release)) #2 Fri Oct 27 01:00:29 EDT 2006
Checking for extra DRAM:
c1000000: wrote ffffffff, read e28cc001
empeg-car player (hardware revision 9, serial number 30102571) 16MB DRAM
Command line: mem=16m
Memory: 15008k/16M available (988k code, 20k reserved, 364k data, 4k init)
Linux NET4.0 for Linux 2.2
IP Protocols: ICMP, UDP, TCP
Starting kswapd v 1.5
Signature is 206f6972 'rio '
Tuner: loopback=0, ID=-1
empeg display initialised.
empeg dsp audio initialised
empeg dsp mixer initialised
empeg dsp initialised
Could not find CS4231A (version=80) --> no visuals for Tuner/AUX.
empeg state support initialised 0089/88c1 (save to d0005d00).
empeg RDS driver initialised
empeg single channel IDE
Probing primary interface...
ide_data_test: wrote 0x0000 read 0xffff
ide_data_test: wrote 0xffff read 0xffff
ide_data_test: wrote 0xaaaa read 0xfffe
ide_data_test: wrote 0x5555 read 0xfff5
smc chip id/revision 0x3349
SMC9194: SMC91C94(r:9) at 0x4008000 IRQ:7 INTF:TP MEM:6144b MAC 00:02:d7:26:0a:0b
RAMDISK: Loading 320 blocks [1 disk] into ram disk... |/-\|/-\|/-\|/-\|/-\done.
empeg-pump v0.03 (19980601)
Press Ctrl-A to enter pump...
#291372 - 11/12/2006 02:38 Re: Sometimes it boots, sometimes it doesn't [Re: robricc]
Mmm... almost as if the drive is nearly dead -- sometimes it spins up, sometimes it doesn't.
But then there's also the CS4231A failure...
Indeterminate.
#291373 - 11/12/2006 02:51 Re: Sometimes it boots, sometimes it doesn't [Re: mlord]
robricc
We tried a new drive today and the empeg does the same thing, so that's probably not it.
The drive cable (original) looks OK, but I will change it tomorrow.
#291374 - 11/12/2006 11:15 Re: Sometimes it boots, sometimes it doesn't [Re: robricc]
How about a boot log with *no* drives installed?
