#286604 - 11/09/2006 18:21 MK2 Ethernet Problem
gafrol
Hi all ,
I have a strange problem with my MK2 (Fiirmware v2.01-final) ethernet port. I tried to upload new music with emplode to the unit when I noticed that I was unable to connect to the player through the LAN anymore. It used to work without any problems for years. The rio car has a statically assigned ip address (192.168.0.13/24).
When I ping the player from my PC I get this :
Reply from 192.168.0.13: bytes=32 time<1ms TTL=255
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
This goes on and on. I already replaced Lan cables and tried to directly link to the PC with a crossed Lan cable, but I still get this time outs. I also connected the rio car to the Lan port of my notebook, but still the same results. The same when I changed the IP address of the player, no help. Also it's not a Firewall issue or anything like that.
It must be something on the ethernet port of the MK2.
Is there anything I can do to fix this or to analyze this further ?
Tnx
Roland
#286605 - 11/09/2006 18:23 Re: MK2 Ethernet Problem [Re: gafrol]
It's possible that there's a hardware issue with the player. Get a serial port log and see if it gives you any errors.
#286606 - 11/09/2006 18:34 Re: MK2 Ethernet Problem [Re: tfabris]
gafrol
Thanks for the fast reply. Here is the log:
e000 v1.04
Copying kernel...
Calling linux kernel...
Linux version 2.2.14-rmk5-np17-empeg55 (peter@tatu) (gcc version 2.95.3 20010315 (release)) #20 Tue Jul 6 15:36:06 BST 2004
Checking for extra DRAM:
c0c00000: wrote ffffffff, read 9afffff0
empeg-car player (hardware revision 7, serial number 90000671)
Command line: mem=12m
Memory: 10968k/12M available (964k code, 20k reserved, 332k data, 4k init)
Linux NET4.0 for Linux 2.2
IP Protocols: ICMP, UDP, TCP
Starting kswapd v 1.5
Signature is ffffffff ''
empeg display initialised.
empeg dsp audio initialised
empeg dsp mixer initialised
empeg dsp initialised
empeg state support initialised 0089/88c1 (save to d0004600).
empeg RDS driver initialised
empeg single channel IDE
Probing primary interface...
hdb: IC25N030ATCS04-0, ATA DISK drive
hda: IBM-DARA-212000, ATA DISK drive
hda: IBM-DARA-212000, 11513MB w/418kB Cache, CHS=23392/16/63
hdb: IC25N030ATCS04-0, 28615MB w/1768kB Cache, CHS=58140/16/63
smc chip id/revision 0x3349
SMC9194: SMC91C94(r:9) at 0x4008000 IRQ:7 INTF:TP MEM:6144b MAC 00:02:d7:12:02:9f
Partition check:
hdb: [PTBL] [3648/255/63] hdb1 < hdb5 hdb6 > hdb2 hdb3 hdb4
empeg-pump v0.03 (19980601)
Press Ctrl-A to enter pump...ԕjչѕɽсɁѕɕ)5change_root: old root has d_count=1
Mounting proc
Starting player
player.cpp : 385:empeg-car 2.01 2004/07/06.
Prolux 4 empeg car - 2.1434 Jul 5 2004
Vcb: 0x4054d000
Restored terminal settings
Abnormal player termination
Player received SIGINT, user interruption
Starting bash.
And here is the output of the diagnostic test:
0000 empeg-car board test version 0.04 <hugo@empeg.com>
0100 ram test starting
0110 testing ic 1 (0-3mb, low word)
0120 testing ic 2 (0-3mb, high word)
0130 testing ic 3 (4-7mb, low word)
0140 testing ic 4 (4-7mb, high word)
0150 testing ic 19 (8-11mb, low word)
0160 testing ic 32 (8-11mb, high word)
01f0 ram test done
0200 ide detect
0210 command issued
0220 drive id IBM-DARA-212000
02f0 ide ok
0300 dsp/i2c test
03f0 dsp/i2c ok
0400 temperature detect
0410 temperature is 00
04f0 temperature ok
0500 usb detect
0510 usb rev 1012
05f0 usb ok
0600 ethernet detect
0610 ethernet rev 334b
06f0 ethernet ok
0700 cs4231 detect
0710 cs4231 rev a0
07f0 cs4231 ok
00f0 tests complete
To me this looks ok so far.
#286607 - 11/09/2006 18:49 Re: MK2 Ethernet Problem [Re: gafrol]
Hm. Don't see anything particularly wrong there at first glance. HOWEVER... You're running 2.01 rather than 2.0. 2.01 is only useful if you've got extra RAM installed. If you don't have extra RAM, try reinstalling 2.0 final and see if that fixes the problem. Dunno whether I should expect it to fix the problem or not (doubt it), but it's worth a try.
Also, did you check the pins on the ethernet port on the player to make sure they hadn't gotten bent or got peanut butter on them?
#286608 - 11/09/2006 18:59 Re: MK2 Ethernet Problem [Re: tfabris]
Peanut butter???
Remember that the empeg only supports 10/Half Duplex. You might want to see if a hub or switch (or your NIC when directly cross-connected) is set to 100/Full or autonegotiate. A thought.
#286609 - 11/09/2006 19:03 Re: MK2 Ethernet Problem [Re: gafrol]
Visually inspect the RJ-45 socket on the back of the empeg, looking for bad/dirty contacts.
#286610 - 11/09/2006 19:07 Re: MK2 Ethernet Problem [Re: mlord]
gafrol
Ok I downgraded to 2.0, same problem. I usually use icecream instead of peanut butter ;-) I'll check for the pins and the RJ-45 Socket now. My Switch is a dualspeed one supporting 10/100 HDX/FDX. Like I said it worked with the same setup for years. But anyway Im going to try with a crossed cable and manually set XP to 10HDX.
tnx so far!
#286611 - 11/09/2006 19:22 Re: MK2 Ethernet Problem [Re: gafrol]
Yeah, since you said the same layout worked fine for years, assuming you haven't changed the switch, then that's not likely to be the issue.
You've ruled out the **CABLE** by switching to another known-good cable, right?
And you've ruled out the computer by doing similar ping tests to other devices on the network?
#286612 - 11/09/2006 19:32 Re: MK2 Ethernet Problem [Re: tfabris]
gafrol
Correct, and I have found the problem... It was a bad port on my switch :-( The switch has been just trashed with a sledgehammer :-) Sorry guys for the hassle !
All working fine now.
Thanks for your kind support.
rgds
Roland
#286613 - 11/09/2006 19:34 Re: MK2 Ethernet Problem [Re: gafrol]
gafrol
Hmm but really strange it did not work with a crosslink LAN cable. Does XP need a reboot after setting it to 10HDX ? I did not reboot it :-(
#286614 - 11/09/2006 19:45 Re: MK2 Ethernet Problem [Re: gafrol]
It should not require a reboot to set the speed / duplex. Strange. Was your XP box on the right network space / IP?
#286615 - 11/09/2006 19:47 Re: MK2 Ethernet Problem [Re: pgrzelak]
gafrol
Yes it's all within 192.168.0.0/24.
#286616 - 11/09/2006 19:53 Re: MK2 Ethernet Problem [Re: gafrol]
Yeah. In your original diagnosis, you said the crossover cable worked but produced the same intermittent timeouts. Which is why I didn't suspect the switch. If that statmement were true, it would have narrowed down the problem to cable, player, or computer, and specifically ruled out the switch. Are you sure those were the exact results you got with the crossover cable?
#286617 - 11/09/2006 20:21 Re: MK2 Ethernet Problem [Re: tfabris]
gafrol
Yes absolutely. Seems really weired to me. I could reproduce the problem reliably when I put the LAN cable into the bad switch port.
