#281715 - 19/05/2006 19:05 Linux-friendly Gigabit NIC recommendation?
Any recommendations for a linux-friendly (and readily available) PCI gigabit NIC?
A few local shops have the following:
D-Link DGE-530T 10/100/1000Mbps Gigabit PCI Network Adapter
SysKonnect SK 9521 V2.0 Gigabit Network Adapter 32 Bit 10/100/1000Base-T
Trendware - TEG-PCITXR - 10/100/1000Mbps Copper Gigabit PCI Adapter
Netgear - GA311 - 10/100/1000Mbps Gigabit PCI Adapter
Intel Pro 1000/GT Desktop 10/100/1000 Gigabit PCI Network Adapter
Mach Speed - SK-9521 - 10/100/1000 Gigabit PCI Ethernet Adapter
Power Up 10/100/1000 Gigabit PCI Network Adapter
Gigafast - GE1000-AXP - 10/100/1000 Gigabit PCI Network Adapter
Sabrent 10/100/1000 Gigabit PCI Adapter
Linksys - EG1064 - 10/100/1000 Gigabit Network Adapter (pricey at over $85)
Linksys - EG1032 - Instant Gigabit Network PCI Adapter
U.S. Robotics - USR997902 - 10/100/1000 Gigabit PCI Ethernet Adapter
Hiro - H50070 - 10/100/1000 32-bit Low Profile PCI Network Adapter
Zonet - ZEN3300E- 10/100/1000 Gigabit PCI Network Adapter
(I left out some Intel and 3Com models that were over $150)
Thanks,
#281716 - 19/05/2006 20:57 Re: Linux-friendly Gigabit NIC recommendation? [Re: hybrid8]
I imagine that any that say "Broadcom" on the chip will work gangbusters. If you can actually see the card in the packaging, that is.
#281717 - 19/05/2006 22:52 Re: Linux-friendly Gigabit NIC recommendation? [Re: wfaulk]
That's going to be a challenge... Anyone know if any of the above use a broadcom part?
#281718 - 20/05/2006 01:15 Re: Linux-friendly Gigabit NIC recommendation? [Re: hybrid8]
Get the Intel part. Probably any of those listed will work, though, but I actually *have* some Intel GigE stuff here, so I know those are fine, and the driver is from Intel themselves.
Also supported in the current kernels: MyriCOM, NS-DP83820, PE Hamachi GNIC-II, DLink DL2000, Alteon AceNIC/3Com 3C985/NetGear GA620, PE Yellowfin, Realtek 8169, SIS190, SysKonnect SK-98xx/SK-95xx, Marvell Yukon (including a zillion relabelled versions from 3Com, Marvell, Belkin, etc..), etc..
See attached kernel config file for a more complete list, with a few more notes on which ones have Jumbo frames, do NAPI (fast polling for higher throughput), etc..
Pretty much everything seems to be supported.
281754-gige.txt (466 downloads)
#281719 - 20/05/2006 19:33 Re: Linux-friendly Gigabit NIC recommendation? [Re: hybrid8]
SuperQ
Loc: Berlin, DE
intel, that's about the only one I would get out of that list..
broadcom tg3 based also work well, but most of those on the list will be cheapo chipsets.
80gig red mk2 -- 080000125
