#279894 - 20/04/2006 19:02 Drive problem
digitalgunfire
I just reformatted the player using the upgrade. It hangs on 'finding pump' and fails with 'Couldn't find pump error 0x20'
I ran the developer upgrade and it seemed to take.
However, it hangs at the boot screen and if i hyperterminal in I get tons and tons of this:
EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazo
ne - block = 2946096496, count = 1
Remounting filesystem read-only
Kernel panic: EXT2-fs panic (device ide0(3,4)): load_block_bitmap: block_group >
= groups_count - block_group = 524287, groups_count = 4757
Any ideas?
#279895 - 20/04/2006 19:44 Re: Drive problem [Re: digitalgunfire]
Can you post a full boot log? You used the upgrader or builder? The upgrader should have only loaded software, not formatted any partitions. Is this a new drive?
#279896 - 20/04/2006 20:05 Re: Drive problem [Re: pgrzelak]
digitalgunfire
No, it's an old drive.
Here's the story.
I just sold the player so I was going to wipe out all the mp3s on it. My current PC doesn't have a serial port so I figured I'll use emplode to delete all the mp3s.
I delete 'em all and get a few sync errors (I was ripping mp3s and stuff at the same time so I figured it might've been resource problem.)
Then my PC locked up. I rebooted and the player was hanging at the logo. So I figured I'll reformat it. I run the disk builder and it runs fine until it gets to 'Finding pump (preparing first hard disk)'
It runs through this, and then says 'Couldn't find pump - error occured during stage 0x20'
I can still apply the upgrade after this, and it seems to take, but it will either hang at the empeg logo or at 'Building music database'
Here's a complete boot log. This is after I tried the version 3 image just to see if it would change.
Calling linux kernel...
Linux version 2.2.14-rmk5-np17-empeg55 (peter@tatu) (gcc version 2.95.3 20010315 (release)) #15 Mon Jul 25 18:52:48 BST 2005
Checking for extra DRAM:
c1000000: wrote ffffffff, read 9afffff0
empeg-car player (hardware revision 9, serial number 10101694)
Command line: mem=16m
Linux NET4.0 for Linux 2.2
IP Protocols: ICMP, UDP, TCP
Starting kswapd v 1.5
Signature is 67706d65 'empg'
Scheduling custom logo.
empeg display initialised.
empeg dsp audio initialised
empeg dsp mixer initialised
empeg dsp initialised
empeg state support initialised 0089/88c1 (save to d0004280).
empeg RDS driver initialised
empeg single channel IDE
Probing primary interface...
hda: FUJITSU MHT2040AT, ATA DISK drive
hda: FUJITSU MHT2040AT, 38154MB w/2048kB Cache, CHS=4864/255/63
smc chip id/revision 0x3349
SMC9194: SMC91C94(r:9) at 0x4008000 IRQ:7 INTF:TP MEM:6144b MAC 00:02:d7:22:06:9e
Partition check:
RAMDISK: Loading 320 blocks [1 disk] into ram disk... |/-\|/-\|/-\|/-\|/-\done.
empeg-pump v0.03 (19980601)
Mounting proc
No secondary hard disk
Press 'q' now to go into development mode. You Have Zero Seconds To ComðStarting player
player.cpp : 587:empeg-car 3.00-alpha11 2005/07/25.
! tags.cpp : 61:Failed to open tags (0xc0041002).
Prolux 4 empeg car - 2.1485 Jul 25 2005
Vcb: 0x4073a000
endpoint stall(clear stall on ep5)
endpoint stall(clear stall on ep4)
I think the endpoint stalls are because I tried to connect with emplode, just to see if it would work.
#279897 - 20/04/2006 20:07 Re: Drive problem [Re: digitalgunfire]
digitalgunfire
I'm going to go back to 2-developer, just as a test.
#279898 - 20/04/2006 21:08 Re: Drive problem [Re: digitalgunfire]
digitalgunfire
Well, it seems to be working now, it will sync over Emplode.. no idea what fixed it tho.
#279899 - 20/04/2006 21:15 Re: Drive problem [Re: digitalgunfire]
Possibly reflashing it.
#279900 - 21/04/2006 10:57 Re: Drive problem [Re: digitalgunfire]
Mmm.. looks like you were using USB for the emplode connection,, USB has issues with windows.
