dear all,
i haven't been here for years now... time simply doesn't allow..
as one of my two disks in my MkII Empeg now starts to fail i got a new diskdrive (Hitachi Travelstar, 100 GB) and i wanted to upgrade my player - at least i wanted to replace the two existing disks (30+40 GB) with the new one.
i followed the instructions of how to upgrade on riocar.org.
- downloaded software (emplode v2.0)
- installed emplode
- downloades emplode new version v2.10
- downloaded disk-builder (old and newer 20011022) for mk II
- downloaded player images (alpha 3.11 and consumer 2.00 - developer)
- run the disk-builder - it seemed to run ok, stresstest was made
- stopped stress test and installed the consumer 2.00, which also didn't come up with any error.
but now i can't connect to the empeg neither with emplode v2.0 nor emplode v2.1.
when connecting it v2.0 comes to the point "checking media", then player reboots and emplode immidately ends.
when connecting with v2.10 i get an error at "checking database" and i can't do anything further.
when i connect with hyperterminal i get following output:
or forever hold their peace...
e000 v1.04
Copying kernel...
Calling linux kernel...
Linux version 2.2.14-rmk5-np17-empeg52 (rob@aphex) (gcc version 2.95.3 20010315 (release)) #11 Tue Apr 1 18:49:59 BST 2003
empeg-car player (hardware revision 7, serial number 80000143)
Command line: mem=12m
Memory: 10968k/12M available (964k code, 20k reserved, 332k data, 4k init)
Linux NET4.0 for Linux 2.2
IP Protocols: ICMP, UDP, TCP
Starting kswapd v 1.5
Signature is 67706d65 'empg'
Scheduling custom logo.
empeg display initialised.
empeg dsp audio initialised
empeg dsp mixer initialised
empeg dsp initialised
empeg state support initialised 0089/88c1 (save to d0005600).
empeg RDS driver initialised
empeg single channel IDE
Probing primary interface...
hda: HTS541010G9AT00, ATA DISK drive
hda: HTS541010G9AT00, 95396MB w/7539kB Cache, CHS=12161/255/63
smc chip id/revision 0x3349
SMC9194: SMC91C94(r:9) at 0x4008000 IRQ:7 INTF:TP MEM:6144b MAC 00:02:d7:10:00:8f
Partition check:
empeg-pump v0.03 (19980601)
Press Ctrl-A to enter pump..`e5jչѕɽсɁѕɕ)5change_root: old root has d_count=1
Mounting proc
VFS: Can't find an ext2 filesystem on dev ide0(3,4).
Tried to mount /dev/hda4 as ext2 but got error 22
No primary hard disk
No secondary hard disk
Press 'q' now to go into development mode. You Have Zero Seconds To ComplStarting player
! tags.cpp : 61:Failed to open tags (0xc0041002).
Vcb: 0x4054d000
Vcb: 0
Vcb: 65536
Vcb: 0
Vcb: 65536
q
Restored terminal settings
Player exited normally: 0
Starting bash.
empeg:/empeg/bin# ls /drive0
empeg:/empeg/bin#
empeg:/empeg/bin# mount
/dev/root on / type ext2 (ro)
none on /proc type proc (rw)
empeg:/empeg/bin#
so to me it seems as if the disk hasn't been formated correctly or cant be mounted or something like this...
could someone give me a hint of how to handle? is the disk maybe too large for the player? (100 GB)
what could i do?
TeeMcBee
