Well, my empeg is having IDE problems again. The age old
Probing primary interface...
(not finding the drive) issue. I had a similar problem about a year ago, resolderd the IDE head, was still flaky while I had it out of the case, put it back together and it just magically worked.
See previous thread of mine. It has been working since. Until last night, the night before I was supposed to drive to phoenix, of course. I was mucking around with it last night for a while, without avail. Re-soldered the IDE header again, no love. Then I saw
something weird. You'll notice that two of the pins on the cs4231a chip are bridged. This looks like it was a factory thing, because there's no way I could've done that neat of a job on a screw up. So I don't know if this is contributing to my problem or not, because things have apparently been working with it. But the thing I don't know is if this chip is also the IDE controller?
Full boot log, you'll see that the chip is being initialized properly.
e000 v1.04
Copying kernel...
Calling linux kernel...
Linux version 2.2.17-rmk5-np17-empeg52-hijack-v422 (hijack@rtr.ca) (gcc version
2.95.3 20010315 (release)) #2 Mon Apr 4 22:44:52 EDT 2005
Checking for extra DRAM:
c1000000: wrote ffffffff, read e91ba9f0
empeg-car player (hardware revision 9, serial number 30103020) 16MB DRAM
Command line: mem=16m
Memory: 15008k/16M available (984k code, 20k reserved, 368k data, 4k init)
Linux NET4.0 for Linux 2.2
IP Protocols: ICMP, UDP, TCP
Starting kswapd v 1.5
Signature is 636f6972 'rioc'
Tuner: loopback=0, ID=-1
Scheduling custom logo.
empeg display initialised.
empeg dsp audio initialised
empeg dsp mixer initialised
empeg dsp initialised
empeg state support initialised 0089/88c1 (save to d0004400).
empeg RDS driver initialised
empeg single channel IDE
smc chip id/revision 0x3349
SMC9194: SMC91C94(r:9) at 0x4008000 IRQ:7 INTF:TP MEM:6144b MAC 00:02:d7:26:0b:cc
empeg-pump v0.03 (19980601)
Press Ctrl-A to enter pump..........½Ñ.½....ɽ½Ñ....¥.....é..)5ÿKernel panic: VFS: Unable to mount root fs on 03:05
Here are all of the pictures I've taken of various things, including the IDE header.
I'm hesitant to try and undo the solder bridge on the cs4231a chip, I may screw it up unnecesarilly, so if anyone has thoughts on that..
In the mean time, I'll re-solder the IDE header again, I really do not want to go on a 12 hour road trip without music
Edit: fixed a link -wfaulk
