#271470 - 05/12/2005 04:56 stripped screws on hard drive mount
Brandis
Loc: Oklahoma, USA
I just cracked open my Empeg to see if there is a problem with the hard drive cables and all the screws on the sides that hold the shock mount in place are so worn out that the screwdriver cannot get a grip. I guess when I sent it in to support a few years ago they wore them down. Any suggestions to how I can get these out without damaging the player?
Chad MKIIa 30Gb Blue
#271471 - 05/12/2005 05:12 Re: stripped screws on hard drive mount [Re: Brandis]
SonicSnoop
Loc: Triangle, VA
Have you tried using a pair of needle nose pliers and see if you can grip em by the sides of the heads? May be a pain but I have been able to get a few screws worn out like that this way..
#271472 - 05/12/2005 05:22 Re: stripped screws on hard drive mount [Re: SonicSnoop]
Brandis
Loc: Oklahoma, USA
Have you tried using a pair of needle nose pliers ..
Funny you should ask that.. I am actually looking for those right now to give it a try
#271473 - 05/12/2005 12:25 Re: stripped screws on hard drive mount [Re: Brandis]
schofiel
I vastly doubt that - new screws always go in during a service. Both myself and David replaced them as a matter of course with no charge!
I'm not sure what you mean here: are the threads stripped (the screws just turn in the screw holes) or are the heads chewed up?
If it's the former, you will need new sled support brackets with good threads.
If it's the latter, you need pliers with 1cm jaws, and you can easily turn the screws by clamping onto what's left of the heads perpendicular to the casing.
New screws are available.
#271474 - 05/12/2005 12:38 Re: stripped screws on hard drive mount [Re: schofiel]
SE_Sport_Driver
And you'll need to invest in the proper size Phillips screw driver! I beat up the screws on the outside of the empeg by using a #2 instead of a #1.
#271475 - 05/12/2005 17:20 Re: stripped screws on hard drive mount [Re: SE_Sport_Driver]
Indeed. Good tools are always the road to a finer fix. Even with the best tools, though, good technique is required; with poor tools, even better technique.
I read once about a 'one-time' method for removing screws with ruined heads. Mix up some 5 minute epoxy and glue your screwdriver into the screw-head. This takes up the missing volume and allows for better transfer of torque.
I'm with the others, though- grab the proud-standing screw head with pliers. I'd even go so far as recommend some Vice-Grip style instead of needle nose, but it's just another idea to try.
#271476 - 05/12/2005 18:15 Re: stripped screws on hard drive mount [Re: SonicSnoop]
Brandis
Loc: Oklahoma, USA
Well i tried with needle nose and regular pliers and it will not get a grip on those tiny screws. I do not own small channel locks but will see if I can borrow some.
#271477 - 05/12/2005 18:16 Re: stripped screws on hard drive mount [Re: Brandis]
schofiel
Needle nose is just useless. Conventional pliers are better.
#271478 - 05/12/2005 18:20 Re: stripped screws on hard drive mount [Re: schofiel]
Brandis
Loc: Oklahoma, USA
Well I am not trying to point the finger at anyone. I am nothing but pleased with the service I got from David. It doesnt matter how they got this way really..
Your right, I used the wrong terminalogy. They are not stripped, but chewed up so that there is nothing for a screwdriver to grip.
Yeah I am working on the pliers method no luck yet.
Where do i get the scews from?
#271479 - 05/12/2005 21:19 Re: stripped screws on hard drive mount [Re: schofiel]
And these are even better for this kind of job!
#271480 - 05/12/2005 21:37 Re: stripped screws on hard drive mount [Re: Brandis]
AndrewT
Loc: Oxford, UK
If you have a fine blade hacksaw, you could carefully cut a slot for a flat-bladed screwdriver.
#271481 - 05/12/2005 22:39 Re: stripped screws on hard drive mount [Re: mlord]
Cool. I'm surprised that they're not more widely available.
#271482 - 05/12/2005 22:40 Re: stripped screws on hard drive mount [Re: AndrewT]
Just be careful with the fine metal particles. You'll probably get a few by clamping onto the screw with the pliers as well if you're not careful. You don't want it to short out anything on the PCB.
#271483 - 06/12/2005 10:08 Re: stripped screws on hard drive mount [Re: Brandis]
schofiel
I have about 2 million of them here
Mail me on carsupport@empegrepair.com
#271484 - 07/12/2005 00:48 Re: stripped screws on hard drive mount [Re: schofiel]
Happy Birthday tanstaafl.
Rob, If I've told you once, I've told you a billion times: Stop exaggerating. :-)
