I am running v2.00final and Hijack 440. I have about 80GB of tracks on two drives. I am able to successfully run emplode, but when I ran jEmplode v70, I got a segfault error. Now I can't do a manual rebuild or run emplode.
The following is a boot dump, and then the errors I get after a manual database rebuild. Any takers?
e000 v1.04
Copying kernel...
Calling linux kernel...
Linux version 2.2.17-rmk5-np17-empeg52-hijack-v440 (hijack@rtr.ca) (gcc version 2.95.3 20010315 (release)) #2 Fri Sep 23 15:03:11 EDT 2005
Checking for extra DRAM:
c1000000: wrote ffffffff, read e91ba9f0
empeg-car player (hardware revision 9, serial number 30102344) 16MB DRAM
Command line: mem=16m
Memory: 15008k/16M available (984k code, 20k reserved, 368k data, 4k init)
Linux NET4.0 for Linux 2.2
IP Protocols: ICMP, UDP, TCP
Starting kswapd v 1.5
Signature is 67706d65 'empg'
Found custom animation at offset 0x9c37c
Tuner: loopback=0, ID=-1
Scheduling custom logo.
empeg display initialised.
empeg dsp audio initialised
empeg dsp mixer initialised
empeg dsp initialised
empeg state support initialised 0089/88c1 (save to d0005300).
empeg RDS driver initialised
empeg single channel IDE
Probing primary interface...
hda: TOSHIBA MK1031GAS, ATA DISK drive
hdb: TOSHIBA MK4018GAP, ATA DISK drive
hda: TOSHIBA MK1031GAS, 95396MB w/0kB Cache, CHS=1161/255/63
hdb: TOSHIBA MK4018GAP, 38154MB w/0kB Cache, CHS=4864/255/63
smc chip id/revision 0x3349
SMC9194: SMC91C94(r:9) at 0x4008000 IRQ:7 INTF:TP MEM:6144b MAC 00:02:d7:26:09:28
Partition check:
RAMDISK: Loading 320 blocks [1 disk] into ram disk... |#/#-#\#|#/#-#\#|#/#-#\#|#/#-#\#|#/#-#\#done.
empeg-pump v0.03 (19980601)
Press Ctrl-A to enter pump...#&#149;&#149;&#149;&#133;&#145;)5change_root: old root has d_count=1
Trying to unmount old #empeg init 0.8
Mounting proc
Starting player
Timezone: Atlantic/South_Georgia
hijack: removed menu entry: "Serial Port Assignment"
khttpd: listening on port 80
kftpd: listening on port 21
! tags.cpp : 61:Failed to open tags (0xc0041002).
Restored terminal settings
Abnormal player termination
Player received SIGINT, user interruption
Starting bash.
/empeg/bin # rwm
/empeg/bin # ls /drive0/var
config.ini
/empeg/bin # ls /drive1/var
config.ini
/empeg/bin # swapon /swapfile
Adding Swap: 16028k swap-space (priority -1)
/empeg/bin # exit
logout
Shell exit
Starting playTimezone: Atlantic/South_Georgia
er
player(24): user memory violation at pc=0x020e1694, lr=0x74614c20 (bad address=0x4088c000, code 0)
pc : [<020e1694>] lr : [<74614c20>]
sp : bffff81c ip : 65685428 fp : bffff838
r10: 00000000 r9 : bffffca0 r8 : 00000000
r7 : 00000018 r6 : 00000008 r5 : 00297330 r4 : 37272065
r3 : 30372720 r2 : 00000000 r1 : 02152850 r0 : 4088c000
Flags: nZCv IRQs on FIQs on Mode USER_32 Segment user
Control: C0F3D17D Table: C0F3D17D DAC: 00000015
Function entered at [<020e15bc>] from [<020e1484>]
r7 = 4088BFDF r6 = 4088BFE0 r5 = 02152829 r4 = 00000026
Function entered at [<020e1410>] from [<0207ca18>]
r7 = BFFFFCDC r6 = 02152828 r5 = 00000027 r4 = BFFFFCDC
Function entered at [<0207c9c8>] from [<02056200>]
r6 = 02135920 r5 = 0214D814 r4 = 00000000
Function entered at [<02055e84>] from [<02061670>]
r10 = 00000000 r9 = 02112374 r8 = 0214D808 r7 = BFFFFCDC
r6 = 00000000 r5 = 02175B90 r4 = 0000AE86
Function entered at [<02061594>] from [<020322a4>]
r7 = BFFFFD88 r6 = BFFFFD80 r5 = 0214EF4C r4 = 02175B80
Function entered at [<02032200>] from [<0200881c>]
r6 = BFFFFD84 r5 = 0214EF44 r4 = BFFFFD80
Function entered at [<020087e4>] from [<0202fcbc>]
r5 = BFFFFD80 r4 = BFFFFD8C
Function entered at [<0202fa0c>] from [<0202f758>]
r10 = BFFFFEE4 r9 = 00000001 r8 = 0214D808 r7 = BFFFFEE8
r6 = 00000086 r5 = BFFFFDF4 r4 = BFFFFDF4
Function entered at [<0202f718>] from [<02031668>]
r6 = 00000086 r5 = FFFFFFFF r4 = BFFFFDF4
Function entered at [<02031464>] from [<02031794>]
r10 = 02031730 r9 = 00000000 r8 = 02112060 r7 = 00000000
r6 = 020000C0 r5 = 00000001 r4 = BFFFFF64
Function entered at [<02031730>] from [<020c8ea4>]
r5 = BFFFFF64 r4 = 00000001
Function entered at [<020c8dc8>] from [<02000104>]
r10 = 00000000 r8 = 00000000 r7 = 00000000 r6 = 00000000
r5 = 00000000 r4 = 00000000
#Restored terminal settings
Player received signal 11
Starting bash.
/empeg/bin #
Edited by errol (24/10/2005 18:17)
