#262368 - 06/08/2005 17:39 Switched drives from mk2 to mk2a, now problems...
ithoughti
Loc: Boston, MA USA
Hi all, I need a bit of help with this. I switched my drives over from my mk2 to my mk2a and now the player won't boot properly. Thanks for any help!
The display says "initialise mixer failed" and then the player restarts etc, etc, etc... here is the Hyperterminal:
e000 v1.04
Copying kernel...
Calling linux kernel...
Uncompressing Linux.................................... done, booting the kernel
Linux version 2.2.14-rmk5-np17-empeg41 (mac@aphex.internal.empeg.com) (gcc versi
on 2.95.2 19991024 (release)) #132 Wed Jan 10 13:49:24 GMT 2001
Processor: Intel StrongARM-11
empeg-car player (hardware revision 9, serial number 120001067)
Command line: mem=16m
Memory: 15048k/16M available (972k code, 20k reserved, 336k data, 8k init)
Linux NET4.0 for Linux 2.2
IP Protocols: ICMP, UDP, TCP
Starting kswapd v 1.5
Signature is 206f6972 'rio '
Logo type is 1
empeg display initialised.
empeg dspaudio driver initialized
empeg infra-red support initialised.
empeg state support initialised 0089/88c1 (save to d0004780).
empeg single channel I
Probing primary interface...
hda: IBM-DARA-212000, ATA DISK drive
hdb: IBM-DJSA-220, ATA DISK drive
hda: IBM-DARA-212000, 11513MB w/418kB Cache, CHS=23392/16/63
hdb: IBM-DJSA-220, 19077MB w/1874kB Cache, CHS=38760/16/63
smc chip id/revision 0x3349
SMC9194: SMC91C94(r:9) at 0x4008000 IRQ:7 INTF:TP MEM:6144b MAC 00:02:d7:18:04:2
b
Partition check:
empeg-pump v0.03 (19980601)
Freeing unused kernel memory: 8k init player.cpp : 385:empeg-car 2.00 20
03/04/01.
! player.cpp : 291:MainThread::Init failed!
Switching to shell-pla
Starting bash.
úShell exit
Starting bash.
úShell exit
l exit
Starting bash.
úShell exit
player.cpp : 385:e
exit
Starting bash.
úShell exit
exit
Starting bash.
úShell exit
Starting bash.
no shell!
Shell exit
Starting bash.
úShell exit
exit
exit
Starting bash.
úShell exit
etc....etc...etc...
//matt
#262369 - 06/08/2005 19:11 Re: Switched drives from mk2 to mk2a, now problems... [Re: ithoughti]
Hmmm... The way it is looping - are the firmware versions matching from both players? Are you using a consumer version of the player software? You might want to try to break to shell and look around a bit.
#262370 - 18/08/2005 15:07 Re: Switched drives from mk2 to mk2a, now problems... [Re: pgrzelak]
schofiel
You need to re-flash the player firmware.
