#260124 - 11/07/2005 00:24 Video file conversion software
Can anyone recommend a program for video file format conversion.
Specifically I want to convert the liberated (drm removed) tivo to go mpeg2 files to something else like mpeg or divx maybe.
#260125 - 11/07/2005 00:41 Re: Video file conversion software [Re: msaeger]
I use TyTool to extract and convert to VOB. From there I use Dr. DivX to go to DivX if necessary, or I just burn straight to a DVD.
Not sure if that will work with Tivo To Go files.
#260126 - 11/07/2005 00:46 Re: Video file conversion software [Re: msaeger]
AndrewT
Loc: Oxford, UK
I believe that the long answer to your request is to be found on the DealDatabase Forum.
Like you, I'm also interested in a convenient way of performing TiVo video extraction. A year or so ago, it was a bit hit & miss aligning the video and audio streams and certainly a hacker's rather than a consumer's solution. After a brief glimpse, I believe that has all changed but I have a few networking infrastructure things to finalise here before I'm ready to attempt video extraction!
In order to reach the proper target readership, I think this thread title probably should have included words like "TiVo, video & extraction" - if you don't get some authoritative replies here then I suggest trying again using those terms. Meanwhile, I'll sit here quietly on the sidelines!
#260127 - 11/07/2005 00:58 Re: Video file conversion software [Re: JBjorgen]
I don't think I need the tytool part becuase I already have plain mpeg2 files without DRM.
I tried the divx converter program
Link. It works but I would like more options.
I don't know what Dr divx was like and they stopped offering that. With this new program you just get a window to drag files to and you can choose from some preset quailty settings. (unless I am missing some options menu ?)
#260128 - 11/07/2005 01:02 Re: Video file conversion software [Re: AndrewT]
I'm not having a problem with the extraction. I have a series 2 so I just have to use the tivo desktop program to get the files to my computer. After that I used this program to get rid of the drm stuff and leave me with a mpeg2 file.
I just want to convert the mpeg2 files to something smaller. (file size wise)
#260129 - 11/07/2005 21:22 Re: Video file conversion software [Re: msaeger]
Foz
Loc: San Jose, CA
If you're using Linux, try transcode. It's the swiss-army-knife of the conversion world.
-- Foz
Eeyore, Original Owner -- Mk II 80 Gb, Blue S/N #090000803 Tigger, 2nd Owner -- Mk IIa, 80 Gb, Blue S/N #40103789
#260130 - 12/07/2005 00:43 Re: Video file conversion software [Re: msaeger]
SE_Sport_Driver
I'm actually using TyTool as I'm reading this thread! The menu creation options are limited, but it's a great program! Tytool will export to MPEG2 if you want to skip the DVD step.
EDIT: As I read your later replies, I see that Tytool won't really help in your situation.
Edited by SE_Sport_Driver (12/07/2005 00:46)
#260131 - 12/07/2005 21:52 Re: Video file conversion software [Re: msaeger]
lectric
Loc: New Orleans, LA
I am also having the same issue. Sortof. I use Nero to burn the images, but I have this one file that's a 4.9G Mpeg-2 file. Nero just says it can't fit it onto a disc and as of yet, I can't find a good transcoding solution for mpeg-2.
#260132 - 12/07/2005 21:54 Re: Video file conversion software [Re: lectric]
SE_Sport_Driver
DVD-Shrink help you fit it onto one DVD. It's a great program.
#260133 - 12/07/2005 21:59 Re: Video file conversion software [Re: SE_Sport_Driver]
lectric
Ahh, I agree, but only from an ISO or DVD-9. I backup every DVD I buy and never play the original. 2 reasons. First, I can scratch the copy all I want and be out 40¢. Second, I can record JUST THE MOVIE and watch it without having to wade through 5 minutes of FBI Warnings and commercials that they won't let you skip through.
